I moved our ArcGIS Server and Portal installations to new servers. I feel like I am very close to get everything up and running properly but have problems with federating the server with Portal correctly.
I had troubles unfederating the old machine (error saying, that the server can't be unfederated and while I wanted to add the new server, it was stating, that it is already federated). So i then went to this page:
https://portalurl:7443/arcgis/sharing/rest/portals/self/servers, registered the new server, and unregistered the old server. Restarted the Portal and all looked good in the Portal settings too. The old servername was gone and the new one appeared:
Same in the Portal Admin Dir:
Would it be safe to change the Portal properties under this link: https://serverurl:6443/arcgis/admin/security/config/update
Where do I find the PortalSecretKey and the webgisServerTrustKey in that case?
Any help is highly appreciated!
