import arcgisscripting gp = arcgisscripting.create(9.3) gp.overwriteoutput = 'true' # here's where you need to define some variables, only 4: gp.workspace = r'< insert full root path to directory containing image tiles >' coord_system = 'PROJCS[< insert coord sys params here >]' GridName = '< your shapefile (you can convert to fc later, as you wish) >' IMAGEfldLen = < your numeric length value for the image name field (suggest 50 or less) > gp.CreateFeatureClass_management(gp.workspace, GridName, 'POLYGON', '', '', '', coord_system) fields = ['IMAGE', 'XMIN', 'XMAX', 'YMIN', 'YMAX'] gp.AddField_management(GridName, fields[0], 'TEXT', '', '', IMAGEfldLen) for i in range(1, 5): gp.AddField_management(GridName, fields, 'DOUBLE', 18, 17) print "added field: " + fields rasters = gp.ListRasters() arrayObj = gp.CreateObject('Array') outRows = gp.InsertCursor(GridName) for raster in rasters: extent = gp.describe(raster).extent arrayObj.add(extent.lowerleft) arrayObj.add(extent.lowerright) arrayObj.add(extent.upperright) arrayObj.add(extent.upperleft) arrayObj.add(extent.lowerleft) feat = outRows.NewRow() feat.Shape = arrayObj image = '.\\' + raster feat.SetValue('IMAGE', image) feat.SetValue('XMIN', extent.xmin) feat.SetValue('YMIN', extent.ymin) feat.SetValue('XMAX', extent.xmax) feat.SetValue('YMAX', extent.ymax) outRows.InsertRow(feat) arrayObj.RemoveAll() del outRows
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
