Ok got it fixed. Your field names being different from mine definitely caused some problems. Also, the range and township fields were of float type, which was causing problems as well. I copied those fields as short ints to fix the problem. This now works perfectly for me. Here is the solution, all that you will need to change is the path to the Owner_Surface feature class. import arcpy, sys, traceback sections = r'C:\TESTING\TestData\TestData.gdb\Owner_Surface' def Quads(sections): urows = arcpy.UpdateCursor(sections) for row in urows: if row.quad == 1: row.setValue('QUAD_LBL','N W') urows.updateRow(row) elif row.quad == 2: row.setValue('QUAD_LBL','N E') urows.updateRow(row) elif row.quad == 3: row.setValue('QUAD_LBL','S W') urows.updateRow(row) elif row.quad == 4: row.setValue('QUAD_LBL','S E') urows.updateRow(row) del row, urows try: # add fields arcpy.AddField_management(sections, 'QUAD_LBL', 'TEXT','','', 3) arcpy.AddField_management(sections, 'LABEL', 'TEXT','','', 15) arcpy.AddField_management(sections, 'townshp2', 'SHORT') arcpy.AddField_management(sections, 'range2', 'SHORT') # update new field for quads label Quads(sections) # Generate full label field urows = arcpy.UpdateCursor(sections) for row in urows: row.townshp2 = row.township row.range2 = row.range quad = row.QUAD_LBL # splits by space in new quad field twp = row.townshp2 rng = row.range2 sec = row.section_ row.LABEL = 'T%s%s R%s%s Sec%s' %(twp, quad.split(' ')[0], rng, quad.split(' ')[-1], sec) urows.updateRow(row) del row, urows print 'Done' except: # Get the traceback object tb = sys.exc_info()[2] tbinfo = traceback.format_tb(tb)[0] # Concatenate information together concerning the error into a message string pymsg = "PYTHON ERRORS:\nTraceback info:\n" + tbinfo + "\nError Info:\n" + str(sys.exc_info()[1]) msgs = "ArcPy ERRORS:\n" + arcpy.GetMessages(2) + "\n" # Return python error messages for use in script tool or Python Window arcpy.AddError(pymsg) arcpy.AddError(msgs) # Print Python error messages for use in Python / Python Window print pymsg + "\n" print msgs I also used a print statement to show the labels being populated:T21S R7E Sec36T30S R12W Sec34T14N R2E Sec18T2N R25W Sec2Done
"T" & [Township] & [northsouth] & " R" & [Range] & [eastwest] & " Sec" & [Section]
import arcpy sections = r'G:\PLSS\PLSS.mdb\Sections' def Quads(sections): urows = arcpy.UpdateCursor(sections) for row in urows: if row.Quad == '1': # if string type row.QUAD_LBL = 'N W' urows.updateRow(row) elif row.Quad == '2': row.QUAD_LBL = 'N E' urows.updateRow(row) elif row.Quad == '3': row.QUAD_LBL = 'S W' urows.updateRow(row) elif row.Quad == '4': row.QUAD_LBL = 'S E' urows.updateRow(row) del row, urows try: # add fields arcpy.AddField_management(sections, 'QUAD_LBL', 'TEXT','','', 3) arcpy.AddField_management(sections, 'LABEL', 'TEXT','','', 15) # update new field for quads label Quads(sections) # Generate full label field urows = arcpy.UpdateCursor(sections) for row in urows: quad1 = row.QUAD_LBL.split(' ')[0] # splits by space in new quad field quad2 = row.QUAD_LBL.split(' ')[-1] twp = row.Township rng = row.Range sec = row.Section row.LABEL = 'T%s%s R%s%s Sec%s' %(twp, quad1, rng, quad2, sec) urows.updateRow(row) del row, urows except Exception as e: print e.message # If using this code within a script tool, AddError can be used to return messages # back to a script tool. If not, AddError will have no effect. arcpy.AddError(e.message)
for row in urows: if row.Quad == 1: row.QUAD_LBL = 'N W' urows.updateRow(row) elif row.Quad == 2: row.QUAD_LBL = 'N E' urows.updateRow(row) elif row.Quad == 3: row.QUAD_LBL = 'S W' urows.updateRow(row) elif row.Quad == 4: row.QUAD_LBL = 'S E' urows.updateRow(row) del row, urows
Ah that is an easy fix. I had it set up for if your quad field was of text type. All you need to do is remove the single quotes wrapping around the value: for row in urows: if row.Quad == 1: row.QUAD_LBL = 'N W' urows.updateRow(row) elif row.Quad == 2: row.QUAD_LBL = 'N E' urows.updateRow(row) elif row.Quad == 3: row.QUAD_LBL = 'S W' urows.updateRow(row) elif row.Quad == 4: row.QUAD_LBL = 'S E' urows.updateRow(row) del row, urows Did it work with this change?
import arcpy sections = r'G:\PLSS\PLSS.mdb\Sections' def Quads(sections): urows = arcpy.UpdateCursor(sections) for row in urows: if row.Quad == 1: row.setValue('QUAD_LBL','N W') urows.updateRow(row) elif row.Quad == 2: row.setValue('QUAD_LBL','N E') urows.updateRow(row) elif row.Quad == 3: row.setValue('QUAD_LBL','S W') urows.updateRow(row) elif row.Quad == 4: row.setValue('QUAD_LBL','S E') urows.updateRow(row) del row, urows try: # add fields arcpy.AddField_management(sections, 'QUAD_LBL', 'TEXT','','', 3) arcpy.AddField_management(sections, 'LABEL', 'TEXT','','', 15) # update new field for quads label Quads(sections) # Generate full label field urows = arcpy.UpdateCursor(sections) for row in urows: quad1 = row.getValue('QUAD_LBL').split(' ')[0] # splits by space in new quad field quad2 = row.getValue('QUAD_LBL).split(' ')[-1] twp = row.getValue('Township') rng = row.getValue('Range') sec = row.getValue('Section') row.setValue('LABEL','T%s%s R%s%s Sec%s' %(twp, quad1, rng, quad2, sec)) urows.updateRow(row) del row, urows except Exception as e: print e.message # If using this code within a script tool, AddError can be used to return messages # back to a script tool. If not, AddError will have no effect. arcpy.AddError(e.message)
hmmm, perhaps the row.setValue may work here: import arcpy sections = r'G:\PLSS\PLSS.mdb\Sections' def Quads(sections): urows = arcpy.UpdateCursor(sections) for row in urows: if row.Quad == 1: row.setValue('QUAD_LBL','N W') urows.updateRow(row) elif row.Quad == 2: row.setValue('QUAD_LBL','N E') urows.updateRow(row) elif row.Quad == 3: row.setValue('QUAD_LBL','S W') urows.updateRow(row) elif row.Quad == 4: row.setValue('QUAD_LBL','S E') urows.updateRow(row) del row, urows try: # add fields arcpy.AddField_management(sections, 'QUAD_LBL', 'TEXT','','', 3) arcpy.AddField_management(sections, 'LABEL', 'TEXT','','', 15) # update new field for quads label Quads(sections) # Generate full label field urows = arcpy.UpdateCursor(sections) for row in urows: quad1 = row.getValue('QUAD_LBL').split(' ')[0] # splits by space in new quad field quad2 = row.getValue('QUAD_LBL).split(' ')[-1] twp = row.getValue('Township') rng = row.getValue('Range') sec = row.getValue('Section') row.setValue('LABEL','T%s%s R%s%s Sec%s' %(twp, quad1, rng, quad2, sec)) urows.updateRow(row) del row, urows except Exception as e: print e.message # If using this code within a script tool, AddError can be used to return messages # back to a script tool. If not, AddError will have no effect. arcpy.AddError(e.message) If this doesnt work, would you mind posting just a subset of your data so I could test and figure out what is going wrong?PS I just had to fix something else in this
This is awsome! Works like a charm, Thank you so very much!
