'''**************************************************************************** Name: ASCII3D_to_Feature_Class Example Description: This script demonstrates how to use the ASCII3D_to_Feature_Class tool to create a point feature class from a set of text files in the specified workspace. ****************************************************************************''' # Import system modules` import arcpy, os from arcpy import env import exceptions, sys, traceback try: #prjFile = os.path.join(arcpy.GetInstallInfo()["InstallDir"], # "M:/GIS/ArcGIS 10 Coordinate System Files and Projections/ArcGIS 10 Coordinate System Files and Projections/Coordinate Systems/Projected Coordinate Systems/National Grids/Australia/GDA 1994 MGA Zone 55.prj") #CS = arcpy.SpatialReference(prjFile) # Obtain a license for the ArcGIS 3D Analyst extension arcpy.CheckOutExtension("3D") # Set environment settings env.workspace = "M:/GIS/data" # Set Local Variables inFormat = "XYZ" # Name of the output file outFC = "90MileBeachPts_from_ASCII.shp" # Geometry of the output feature class outType = "MULTIPOINT" zFactor = 1 # Coordinate system of the output feature class CS = "GDA 1994 MGA Zone 55.prj" fileSuffix = "mga55.xyz" decSep = "DECIMAL_POINT" # Specifies the decimal delimeter # Create list of ASCII files txtList = arcpy.ListFiles("*" + fileSuffix) # Verify the presence of TINs in the list if len(txtList) > 0: # Execute ASCII3D_to_Feature_Class arcpy.ASCII3DToFeatureClass_3d(txtList, inFormat, outFC, outType, zFactor,CS, 2.0, fileSuffix, decSep) except arcpy.ExecuteError: print arcpy.GetMessages() except: # Get the traceback object tb = sys.exc_info()[2] tbinfo = traceback.format_tb(tb)[0] # Concatenate error information into message string pymsg = 'PYTHON ERRORS:\nTraceback info:\n{0}\nError Info:\n{1}'\ .format(tbinfo, str(sys.exc_info()[1])) msgs = 'ArcPy ERRORS:\n {0}\n'.format(arcpy.GetMessages(2)) # Return python error messages for script tool or Python Window arcpy.AddError(pymsg) arcpy.AddError(msgs)
CS = "Geographic Coordinate Systems/GDA 1994 MGA Zone 55"
'''**************************************************************************** Name: ASCII3D_to_Feature_Class Example Description: This script demonstrates how to use the ASCII3D_to_Feature_Class tool to create a point feature class from a set of text files in the specified workspace. ****************************************************************************''' # Import system modules` import arcpy from arcpy import env import exceptions, sys, traceback try: # Obtain a license for the ArcGIS 3D Analyst extension arcpy.CheckOutExtension("3D") # Set environment settings env.workspace = "M:/GIS/LidarProd/XYZToFeature/Missing Lidar from DSE 21022013/elevation/cep2007-08_srw-90mb/regular_surface/dem_ground/xyz_ascii" # Set Local Variables inFormat = "XYZ" # Name of the output file outFC = "90MileBeachPts_from_ASCII.shp" # Geometry of the output feature class outType = "MULTIPOINT" zFactor = 1 # Coordinate system of the output feature class CS = "Geographic Coordinate Systems/GDA 1994 MGA Zone 55.prj" fileSuffix = "mga55.xyz" decSep = "DECIMAL_POINT" # Specifies the decimal delimeter # Create list of ASCII files txtList = arcpy.ListFiles("*" + fileSuffix) # Verify the presence of TINs in the list if len(txtList) > 0: # Execute ASCII3D_to_Feature_Class arcpy.ASCII3DToFeatureClass_3d(txtList, inFormat, outFC, outType, zFactor, CS, fileSuffix, decSep) except arcpy.ExecuteError: print arcpy.GetMessages() except: # Get the traceback object tb = sys.exc_info()[2] tbinfo = traceback.format_tb(tb)[0] # Concatenate error information into message string pymsg = 'PYTHON ERRORS:\nTraceback info:\n{0}\nError Info:\n{1}'\ .format(tbinfo, str(sys.exc_info()[1])) msgs = 'ArcPy ERRORS:\n {0}\n'.format(arcpy.GetMessages(2)) # Return python error messages for script tool or Python Window arcpy.AddError(pymsg) arcpy.AddError(msgs)
'''**************************************************************************** Name: ASCII3D_to_Feature_Class Example Description: This script demonstrates how to use the ASCII3D_to_Feature_Class tool to create a point feature class from a set of text files in the specified workspace. ****************************************************************************''' # Import system modules` import arcpy, os from arcpy import env import exceptions, sys, traceback try: prjFile = os.path.join(arcpy.GetInstallInfo()["InstallDir"], "M:/GIS/ArcGIS 10 Coordinate System Files and Projections/ArcGIS 10 Coordinate System Files and Projections/Coordinate Systems/Projected Coordinate Systems/National Grids/Australia/GDA 1994 MGA Zone 55.prj") CS = arcpy.SpatialReference(prjFile) # Obtain a license for the ArcGIS 3D Analyst extension arcpy.CheckOutExtension("3D") # Set environment settings env.workspace = "M:/GIS/LidarProd/XYZToFeature/Missing Lidar from DSE 21022013/elevation/cep2007-08_srw-90mb/regular_surface/dem_ground/xyz_ascii" # Set Local Variables inFormat = "XYZ" # Name of the output file outFC = "90MileBeachPts_from_ASCII.shp" # Geometry of the output feature class outType = "MULTIPOINT" zFactor = 1 # Coordinate system of the output feature class #CS = "Geographic Coordinate Systems/GDA 1994 MGA Zone 55.prj" fileSuffix = "mga55.xyz" decSep = "DECIMAL_POINT" # Specifies the decimal delimeter # Create list of ASCII files txtList = arcpy.ListFiles("*" + fileSuffix) # Verify the presence of TINs in the list if len(txtList) > 0: # Execute ASCII3D_to_Feature_Class arcpy.ASCII3DToFeatureClass_3d(txtList, inFormat, outFC, outType, zFactor, CS, fileSuffix, decSep) except arcpy.ExecuteError: print arcpy.GetMessages() except: # Get the traceback object tb = sys.exc_info()[2] tbinfo = traceback.format_tb(tb)[0] # Concatenate error information into message string pymsg = 'PYTHON ERRORS:\nTraceback info:\n{0}\nError Info:\n{1}'\ .format(tbinfo, str(sys.exc_info()[1])) msgs = 'ArcPy ERRORS:\n {0}\n'.format(arcpy.GetMessages(2)) # Return python error messages for script tool or Python Window arcpy.AddError(pymsg) arcpy.AddError(msgs)
