After the most recent update to ArcGIS Online I have not been able to add a layer to a map using the "Add layer" function in Map Viewer. I am still able to add layers via URL, but not using the "Add" button at the bottom of the layer list. Is anyone else seeing this issue, or know of a simple solution. Clearing browser cache did not work.
@JeremyBrown4
This sounds so obvious, but I'll say it anyway. After every update I communicate to users that it's really important that they delete their browser caches to lessen any possible issues. The browser I use for AGOL is actually set to delete cache etc on close.
Hi @JeremyBrown4 , thanks for posting the question. To investigate into the issue,
Thanks for sharing more details, @JeremyBrown4.
Are you accessing ArcGIS Online from a bookmark in the browser? Or are you signed into a different ArcGIS Online organization when this reproduces? Do you replicate the same behavior using an incognito window in Google Chrome?
I do launch AGOL from a bookmark, not signed in to any other orgs and the issue persists in incognito mode. I added the clear cache on close setting that @JonathanMcD mentioned and that seems to have helped. Not sure why clearing cache manually was not working, but for now my problem seems to have been solved.
Thanks for the update, @JeremyBrown4. I am glad that it's working for you now!
