All numbers were exactly the same size.
There was no Bold at all, now it's a mess.
Arcade scripts that are cut, I still have to figure out how to set the size as it disappeared from the standard settings...
worth checking or adding to it
ArcGIS Online June 2026 Update – Known Issues (Com... - Esri Community
If its not on this list can you add it https://community.esri.com/t5/arcgis-online-questions/arcgis-online-june-2026-update-known-issues/m-p/1711571#M69109 thanks
I have the same issues, the update has totally disrupted the accessibility of our public dashboards. Basic text size options should be standard!
Thanks for bringing this to our attention @PanGIS - I strongly recommend that you contact Esri Technical Support and open a case.You can do that through your My Esri or the Esri Support App
