While the new domain tools in 10.1 are a good addition I would like to be able to manually re-order a domain that is not in any alphabetical order such as below.The Domain Tools from http://resources.arcgis.com/gallery/file/geodatabase/details?entryID=D62A883B-1422-2418-8873-5721AB32134D that could be added to previous arcgis versions were great. Something similar to how that would allow you to manually-ish reorder a domain would be a useful tool.I wasn't able to get that sample to work in 10.1.
My org is using a Domain Sort Add-In tool that had been downloaded many, many years ago which still works in 10.5.1 and hopefully still works in 10.7. The link for the download from the OP does not work (not surprising as it is 7 years old).
Would anyone know if this functionality is already/will be built into ArcMap's successor ArcPro? This is really a core tool for GIS admins so it would be important to make it available to Pro so org's can make a complete migration to Pro.
(Coded value) Domain sorting is supported out of the (tool) box with the Domain Toolset
This doesn't help Peter Russell or anyone else who wants to manually order a domain.
If you feel like hacking there's this....https://community.esri.com/blogs/HackingArcSDE/2014/12/31/re-order-attribute-domain-values
Are you using this hack in Pro? This hack allows you to place coded value domains in any order you like? This is the use case that I am looking at as my org does not have all coded value domains in alpha-numeric order for business reasons. This would be a needed tool if we migrated our SDE admin tasks to Pro, as the Add-In currently used is only available for ArcMap/ArcCatalog.
For a bit of manual 'hacking' it is possible to manually reorder a domain, but it's a real PITA. Hence why this idea is important.
Each time you rename a subtype, it will be tossed to the end of the table, and this is how it will be presented to LE users.
If you want to rename an entry (e.g. 'South Esk Water' to 'Deprecated') and keep its order, you must use the above procedure to rename that subtype and all subsequent subtypes. Do not ask why, just thank Esri for this 'feature'!
It would be a nice feature to manually re-arrange the domain values. But I was able to re-order the domains this way:
Hopefully this helps someone. But I'd still like to be able to manually move them, too.
Hello,
I usually don't post on forums, but I was struggling with this same issue, and I "believe" I found a very simple solution that is working flawlessly for me so far *knock on wood*. For a Condition Domain it was being ordered High > Low > Moderate, but I wanted it to be High > Moderate > Low.
I tried a lot of the ideas on this thread, but what eventually worked best for me was to: open up the domain in ArcGIS Pro, select the domain that I want to reorder, then change the "Code" column to 1, 2, 3 (the order I want the list to appear), saved it - reopened the domain - and the order was exactly how I wanted it to be. You can make the Description column whatever you want.
Before:
Code: HIGH Description: High
Code: MOD Description: Moderate
Code: LOW Description: Low
After:
Code: 1 Description: High
Code: 2 Description: Moderate
Code: 3 Description: Low
Hopefully the simplistic Code values won't cause any unforeseen issues, but with how simple this was to reorder domains, it will definitely be the method I use unless I run into any issues as a result of this method.
Hope this helps someone!
It would be useful if we could reorder the domain code entries manually. In the example below I would like to move "OOJ" to the last entry of the coded value domain table.
Thanks!
Hey Gang,
I think I have a solution.
Seems to work in ArcGIS Pro 2.8.
Have fun!
--pbc
Please add manual sorting of a Domain.
Especially when working with something like #utilitynetwork, this would be very useful. I like @DanielWebb solution, but there is no way to do that within geoprocessing scripting within Python. You have to do it within the UI. A GP tool, that allows you to set the order, so it could be scripted would be very useful.
It would be very useful if domains could be sorted or ordered manually by dragging the coded values from one location in the list to another.
I agree it would be very helpful for a drag and drop reordering for scenarios where you want almost all of a long list ordered alphabetically, but would like a single value at the top/bottom (list of street names with off-road or N/A at the top).
Agree. I have sizes and would like them ordered 2x2 up to 2x23. However it when sorting A-Z it sorts 2x23, 2x23, 2x3 rather than sticking 23 at the end. I need to be able to move the codes manually!
Tried updating a domain today in Pro 3.3.2 and yes, there is the option to sort alphabetically but I (and others in this thread) need my "unknown" and "not applicable" domain choices to be at the bottom of the list, not in the middle. It is customary for us to put the default domain at the top of the list and the unknown and NA at the bottom. Sorting alphabetical doesn't help this.
This thread has been going for a long time and this suggestion seems simple and important.
Yes, the table to domain tool will work but it would be MUCH EASIER to drag and drop or use a tool to reorder the domain table that already exists that is partially editable just not fully editable like we are suggesting.
Thank you for considering Esri 😉
I strongly agree that there should be a way to manually change the order. While workarounds are possible, they also have to be repeated every time the list of values needs to change. Rather that having a new manually entered code forced to the end of the list, it would be much easier to be able to move the new code to the desired position.
In the creation process of domains, sometimes you want to change the order you just entered before saving. Currently there's only the option to a sort the domains (alphabetically) or delete and change text manually.
I would love to see a way to be able to click and drag to re-sort these values when creating a new domain list.
Thanks for your consideration!
Best,
Amanda Huber
Can I kudo it twice?
I get why it would be difficult to allow manual sorting after creation, but here the domain doesn't even exist yet. This would be a welcome improvement!
To add to this. I have issues with the sort sticking. Most of the time, I tell it to sort alphabetically and save, but it reverts back to the original order. I have to delete at type it in manually. Would be great to figure out this bug and love the idea of being able to drag options into a desired order.
@PamelaKing I've seen that behavior before as well. Haven't tested in newer versions of Pro yet though.
Melden Sie sich an, um zu posten, Inhalte zu folgen und mehr. Neu hier? Kostenlos registrieren.
