HI William,I don't see service parameter,but I see "Instance" and the value I provided is rws3260455.us.oracle.com:1521/m12yd223.This is Oracle 11g db host,port and sid.Do you think there is something wrong in this.
Hi William,rws3260455.us.oracle.com is oracle 11g db host name.1521 is db portm12yd223 is Oracle SID.I ahve referred link http://resources.arcgis.com/en/help/main/10.2/index.html#/Database_connections_in_ArcGIS_for_Desktop/019v00000003000000/ and provided Instance as rws3260455.us.oracle.com:1521/m12yd223With this syntax I am able to succesfully create datbase connection in Desktop but registering the database with gis server fails.Is there any other setup that we need to do for this .Please suggest.
Hi William,I have followed the manual process and able to see the database registered.But when I click on "Validate All" it is invalidated,this could be because of wrong password.But there is no way to edit the password.
Hello, I see this is an older post, but just wanted to check if you were able to call Esri Support and find a resolution to this issue? If you were able to get around the issue (either with or without support), do you have the details that helped you move forward?
Sincerely,
TM
