How many items are there in a list? If number is more than 5000 then take subset of list and try configuring geocoding workflow. Do you see list of locators now?Also try configuring geocoding workflow from different machine/browser.
I am having the same issue. I am too https for Sharepoint and the http/https did bugger things up when I was tyring to get the base maps and layers configured. Did you ever resolve this issue?
After a 2.5 hour phone support call with Technical Support at ESRI Canada I was able to resolve this issue. I do have other issues still, but this one has been solved. Here's what I know and hopefully it will help you as well:If your sharepoint site is "https" then all of the basemap, connections, geoemetry service and locator URL's must too be "https". The BING and ARCGIS Online URL's work when you simply change them to "https". The Open Map doesn't seem to workAs for the locator/address fields coming up blank - this is a result of a defined locator not being accessible. If one is not accessible, the whole list shows up empty. If you added any custom locators, I'd start by deleting them from the configuration and then seeing if it works.I am having a problem getting the ArcGIS Online locators to work when I set-up my workflow. According to technical support the issue is because this process is actually run on the Sharepoint server and not within the browser. My workflow fails because a "trust relationship for the SSL/TLS secure channel" could not be established. This means that the firewall on my Sharepoint server is not allowing communication with ArcGIS Online. The same error occurs when I add one of my own locators. I still have to remedy this issue. When I have it fixed, I will repost the result. Hope this helps!
