In web maps on ArcGIS Online there is an option within the "Time slider options" called "Playback position" -> "Play from position saved with the map".
Is there anyway to achieve a similar outcome with the Time Slider widget in ArcGIS Experience Builder? I have tried the option "Time settings" -> "Synchronize with time settings in the web map" - but this does not change the playback position from the start time.
I'm also interested in the answer to this. I have tried the same thing with no luck.
Also interested in this with no luck. esri please help us
I tried to synchronize my ExB with Map viewer setting and I lose not only playback position but also other settings. So I changed it back to customize time setting in ExB. But I'm also looking for setting playback possition in ExB. Does anybody know any workaround.
I wrote idea for this time setting, you can give me a kudo to escalate it: https://community.esri.com/t5/arcgis-experience-builder-ideas/set-start-playback-position-in-timeline-widget/idi-p/1632428/highlight/true
This has been supported in the latest AGOL 2026 Feb release. Let me know if you encounter any other issues with it. Thanks.
I read it in What's new blog and it looks great for me. Thanks for this upgrade.
