Hi All,
Is it possible to remove just 0 labels from my line chart that is based on time/date. I want to total count label to be visible but remove 0's from the chart as well as the same between the different peaks.
Did that nothing changed. To explain further the 0 values don't exist within the data, that's where I am having trouble filtering it out.
Possibly so. Can you change the value of the 0 to a null value, therefore nothing should show up?
Thanks @AdrianWelsh No change unfortunately, is it because it's a date field?
What happens if you do a filter for those values (where the value does not equal 0)? Does it truncate your chart in a way that does not look good?
