In the Reporter Instant App, if there are other layers in the map and one has turned off their popups in the webmap, this has no effect when using the app. It does not honor this. Has anybody found a workaround for this?
Hi, @ArmstKP Its a known issue with reporter and we'll fixing it in the October release.
Hi @SubaKrishnan , how was it addressed in the October release? I WANT to show popups in mine, but nothing happens when I click on them in Reporter even though I can see them in the webmap.
Hi @ChelseaRozek If a popup is turned off in the web map for a non-reporting layer you will not see the popup when clicked on those features in the app. What is the current setting in your map and app, please give me more info on the current behavior and your expected behavior.
Hi @SubaKrishnan I have non-editable layers with popups turned on in my webmap (yellow points). When I click on them in my final app, no popup appears. I hope to be able to click on the points so users can reference previously submitted issues.
Hi @ChelseaRozek I'm able to repro the behavior in your app but not in mine. Did you disable editing at the layer level or map level? Could you verify the popup is also enabled in the map. If it still doesn't work, try opening the config and relaunch the app with/without any changes to see if it changes behavior. Let me know if you still have issues.
So it looks like if you add layers in as a map service (all together), the popups do not work in the final app. I added each layer in the map service (that is published to our own server) as a separate item in AGO and now I can see the popups.
So creating an AGO item from servicename/MapServer, didn't work. Creating ones like servicename/MapServer/1 and then adding those to the webmap allowed the popups to show in the final app. It doesn't seem like this should be necessary if they work fine in the webmap with the first way.
Hi @ChelseaRozek This is weird. Let me test it at my end and log an issue. I'm glad it's working for you now.
Is there any reason to use map server layer as opposed to a view layer?
I'm not sure what you mean. It isn't a hosted feature layer as it's coming from our enterprise geodatabase so I can't make a view off of it. I don't want these points to be editable, so I didn't turn on feature access, so it's only a map service. These are different layers than the editable points. They're just for reference on the map.
Hi @ChelseaRozek This issue is fixed in the recent AGOL release. Please take a look and let me know if you have any questions.
Here is the blog to review new features this release. https://www.esri.com/arcgis-blog/products/arcgis-online/constituent-engagement/whats-new-in-reporter-instant-app-june-2025
Hi @SubaKrishnan , thanks for pointing that out to me, I appreciate it. I tried it out and can see popups now, however they don't adhere to the settings from the webmap. I have popups turned off on a layer, but they still show up in the Reporter app. I have only two fields showing in another layer's popup, but I can see them all in the Reporter app. I tried making a new Reporter app from the same webmap, and I see the same behavior. It's the same layers as before: a map service published to our own ArcGIS server. Let me know if you'd like some screenshots.
Hi Chelsea. I'm glad that you're seeing the popups now. For the second issue, I'd like to know more. Are you referring to reporting or non reporting layers? Is that a hosted layer or map server layers? If you can send the map and app I can look into it, or some screenshots will help me too. Thanks!
@SubaKrishnan They are non-reporting layers on the map for reference and are map server layers not hosted on ArcGIS Online. The app is here. If you zoom in (try bottom right corner), orange hatching and blue drain lines will appear. They should have very simple popups, but unfortunately everything is seen, like OBJECTID. Here's how it looks in the webmap, just 5 attributes with no OBJECTID on the orange hatching:
Thanks @SubaKrishnan ! I can confirm that the AGO update last week has fixed the issue
Hi @ChelseaRozek
Yay! Thank you for confirming the bug fix.
Since you’re an active user of the Reporter app, I’d love to get your thoughts on an approach we’re exploring. We’ve heard from several users that capturing a location’s address and automatically populating it in the form is important to their workflow. Currently, Reporter doesn’t support reverse geocoding for anonymous users because storing results from the ArcGIS World Geocoder consumes credits.
Survey123 handles this by allowing organizations to store credentials with their own locator so credits are charged appropriately.
We’re considering adding a similar option in Reporter, allowing organizations to configure their own locator instead of relying on the ArcGIS World Geocoder. This would avoid credit use and remove the sign-in requirement.
Would this approach work for your workflow, or are there other ways you’d prefer to capture the reporter’s address?
Suba
Hi @SubaKrishnan,
That sounds like it would work for us. We wouldn't be submitting outside of our county, so our address locator should be enough. We only use Reporter in this one application, which is submitting drain requests (like flooding issues). The address is less important to us than the XY of the point, as the drains cross many parcels, but as we do already ask for the address, it would be nice if it could save the submitter time when filling out the questions. We would probably still add in a manual-entry address field for a mailing address for follow-up materials we snail mail them.
