Trying to load a point dataset into ArcGIS Online from ArcGIS Pro. The point data is symbolised with letters in white with a black halo (see attached screenshot). This previously worked in ArcGIS Online, but now the black halo is not showing.
If the data is pulled back into ArcGIS Pro the halo does work. However in ArcGIS Online (Map Viewer) and Field Maps the halo cannot be seen.
Tried changing the halo to a black outline, but this still did not work.
Any suggestions on how to get this outline to come through? This worked previously, perhaps this is an issue following the ArcGIS Online upgrade?
