The active layer on a map - the layer with an associated form and a related table with its own form - have disappeared from the FM app since the update to 25.2.x. The layer is not visible on both the online map and in the offline map areas we created. All the other map layers, none of them active, do show.
A phone still running FM 25.1.x does show the active layer, and phones running 25.2.x but which have not reloaded the offline maps also still show the active layer. If the offline areas are removed and reloaded, however, the active layer disappears.
I see no error messages at all in AGOL, FM Designer, or the mobile app.
Does anyone know what's going on? Is there a way to fix this? The apps are unusable in the current state.
Dan
