Hey all,
Probably the most simple question you'll get today, but where is the placement options for line labels, am I just blind?
Using Enterprise 11.3
Cody
According to this threadhttps://community.esri.com/t5/arcgis-online-questions/where-is-the-label-placement-property-for-lines/td-p/1356010
Line label placement options were added around Q2/Q3 of 2024. So I wonder if 11.3 Portal map viewer was buttoned up before that option was implemented?
EDIT: It seems if you compare the 11.3 to 11.4 documentation, 11.3 does NOT include the note about line label placement.https://enterprise.arcgis.com/en/portal/11.3/use/configure-labels-mv.htm
Yup this was included in the 11.4 enterprise release!
Hey @CalvinHarmin
Ah I see! Very unfortunate, I had thought 11.3 would have caught up to the Online version years back but it seems it much farther behind than I thought! No worries at all though, thank you for your help!
