Hi there,
I'm trying to calculate shortest route from a centroid, along a road network, to nearest bike path, and I'm having an interesting issue with the Closest Facility Analysis tool:
I have 125 081 Facility points (points along a cycling network)
I have 10 272 Incident points (population-weighted dissemination area centroids)
I have a municipal road network (which I have built and forced full rebuilds to see if this was the issue)
When loading the facilities and incident points I used exaggerated search tolerances (100 kilometres to make sure this isn't the issue), unchecked the append option, and allow automatic relocating at solve time.
Everything loads properly, but when I run the tool (direction: away from facility, Facilities: 1, no cutoffs, not using time, Along network), I only get 10 259 routes out of 10 272.
I joined the route table to the centroid table to identify the centroids without routes, and when I locate these centroids I can't figure out why the tool wouldn't calculate a route for them. I've attached an image of an area with several centroids that are missing routes.
Anyone ever experience this, or have any recommendations?
Thank you,
Tim
