when trying to open the hosted services getting Error: Service 'claims_bds_new' does not exist.Code: 500
Thanks! This worked like Charm.
Yes, you should be able to initiate this from any of the machines and the data will copy to the others.
@KannanSundaresan this is a known issue. Take a look at the attached zip file that contains a script and document on how to update the script.
@JakeSkinner, thanks for helping with this issue. I have one other question relating to spatiotemporal datastore restore on a totally different machines in a different location. I have 3 machines spatiotemporal datastore in location A. I want to backup the spatiotemporal datastore from here and restore it to 3 different machines in location B. I know first I need to register the backup location in a share drive so both A and B locations can see it. then backup the spatiotemporal datastore in location A using backupdatastore utility. question is when restoring on location B machines, should I first install spatiotemporal datastore on all 3 machines in location B an configure with arcgis server site on location B, then run restoredatastore from the first machine in the spatiotemporal datastore in location B? is it correct method? or should I not configure the spatiotemporal datastore before running restoredatastore in location B? currently i installed and configured 3 machines in location B.
@KannanSundaresan
Here are the steps to backup/restore your BDS:
Thanks!
