Hi, when opening the Properties for a Locator none of the settings ever load or able to be modified. All I get are a "Loading..." dialog that never returns anything (see image).
Any suggestions on how to fix this would be appreciated.
Susan:
If you have ArcMap available to you, create the locator in ArcMap and add the locator to Pro. Do you get the same behavior accessing the Properties? Also, for the existing locator created in Pro, if you have ArcMap, you should be able to adjust the setting you need and use the locator in Pro.
Do others in your organization have the same problem? If a different user signs onto your machine do they encounter the same problem?
Hi John,
I have created another user and I am having the same problem. I have also uninstalled and reinstalled the software and have completed all of the updates... and I still have the same problem.
Thanks for the suggestion - any other ideas?
Thanks
Susan
Can you create a new local user on your computer
Open ArcGIS Pro and create a locator and do the properties appear?
Hi
The locator was produced using Pro version 2.0.1 and the GeoDB and feature classes produced using this version.
Stephen,
Thanks for answering the questions.
What version of ArcGIS Pro was used to create the address locator?
The geodatabase which contains the feature class, was it also created using ArcGIS Pro?
Just a side note when you use the address locator for geocoding addresses it only accepts address as an input you will be be able to set specific fields as output.
You may refer Geocode Addresses—Help | ArcGIS Desktop
~Shan
Hi Shan
Thanks for responding, answers as follows:
It will be great if you can provide the following information.
