Hello ESRI Members,
What I’ve considered but won't work:
Does anyone know a way to achieve it ?
PS: I think about notebook will be a good for that - I don't know
Any insights would be greatly appreciated!Thanks!
Well, you are going to never have real time processing, but you can use a web hook to trigger an action like creating a point.The best you can hope for, even with GeoEvent or Velocity, is near real time.
Hi @Piotrek6116,
I'm not sure what you mean when you say that Arcade expressions only work in pop-ups. Arcade expressions can be used to update attributes in various places across the platform. Here are some examples of ways you can use arcade expressions to update attributes:
1. Forms - Author forms with calculated expressions to update attributes for the feature(s) you are editing.
2. Calculate field- calculate a field for all (or a subset of) features in a layer in the attribute table using the Calculate field tool.
That being said, updating features automatically when you edit a feature in another layer is not as straightforward. Is there a relationship between the points and the polygons? If the features are related, then you could author expressions in forms that help ensure the polygon attributes are updated anytime a related feature (point) is created or updated.
Otherwise you may want to look for scripts or leverage tools like Notebooks, Data Pipelines or Model Builder that you can schedule or run repeatedly.
Hope that helps - Emily
