ArcGIS Pro 3.4.0
My experience is that georeferencing is buggy in Pro.
What file type is the most stable? TIFF? FGDB? Something else?
PDFs definitely have some bugs in them. For the most part I have found jpgs to behave themselves thoughWhat issues are you having?
Thanks @RichardHowe.
Issues (Pro 3.4.0):
Now that Pro 3.4.2 has been released what issues do people still have that are not yet addressed?
Hi @Bud For imagery & scans out of a pdf I use a simple open source pdf to jpg converter then clean & clip as needed. Some PDF tools try to be 'smart' and add junk to tiff output. Tiff is great when Esri/Erdas/etc make it but not something I go to in the same sentence as pdf.
When you convert said tiff to jpg (not sure what Paint does - I prefer IrfanView for basic raster/bmp handling) it may also incorporate some of the 'bad' metadata from the tiff hence issues. The breaking of georeferencing may be due to a resize in the convert process. More reasons exist.I use png, jpg, jp2000, ecw, and tiff often and usually issues are created at the source and not in Pro; but Pro is less than graceful in handling these mal-formed datasets.... Sounds like an Idea.....Depending on the size I store a lot of raster data in FGDB. Fantastic placebo performance in my setup and it is a native format that Pro should work with without fault; it's also without weird issues like sneeze deleting the georefence file (not that I don't have easy nearline snapshot backups, but if I don't have to spend 2min restoring a backup....).
