Please find attached tiles
Hi Girishchandra Y,
Yes, we support both OpenStreetMap (online) and loading local tiles from disk.
OpenStreetMapLayer Class | ArcGIS for Developers
Also, if you want to use your own, local tiles from disk, please see this section from our documentation on how to do that.
ImageTiledLayer Class | ArcGIS for Developers
Please let us know if this answers your question.
Thank you
Can you please tell... if I want to use same OSM tiles from Database then what will be process
Girishchandra Y,
I had initially replied that it cannot be done, but in fact this can be done. We provide a method on the ImageTiledLayer base class to provide a QByteArray of data for the tiles. You should be able to use this method to load your images directly from the database.
Sorry for the confusion. Let us know if that works for you.
Thank you sir,I have one more doubt is can we load .mbtiles file ...If possible how to do the same.
Girishchandra Y, if you can pull the tile bytes out of the mbtiles file then we should be able to read it. We will not be able to process anything from that file directly.
It always looks for Row 0 and column 0 tile for every Level of Details
Also OSM is giving pbf format ...How to choose that option in
TileImageFormat::
