def main(): import arcpy # settings, replace with your own dataset and existing column name: FClassOrTable = r'C:\Project\_tmp\test.gdb\Mawares' outputField = 'MMax' # .. or make variable # FClassOrTable = arcpy.GetParameterAsText(0) # outputField = arcpy.GetParameterAsText(1) # update featureclass fields = ['SHAPE@',outputField] with arcpy.da.UpdateCursor(FClassOrTable, fields) as cursor: for row in cursor: row[1] = GetMmax(row[0]) cursor.updateRow(row) del row del cursor def GetMmax(geom): # get the max(M) from a geometry mmax = -9999 for part in geom.getPart(): for point in part: m = point.M if m > mmax: mmax = m return mmax if __name__ == '__main__': main()
Instead of using a function to breakdown that Mmax value, you could also just use the extent object, which comes as part of the Shape@. Like this:
with arcpy.da.UpdateCursor(FClassOrTable, fields) as cursor: for row in cursor: row[1] = row[0].extent.MMax
