I've tried adding two videos to a small Map Tour I've put together and not sure if i'm missing a configuration setting for the videos to run within full-size image frame, they currently keep popping in an additional window.
http://mceo.maps.arcgis.com/apps/MapTour/?appid=19c6389b1e1246dfb240db92406cb441
Map Tour points 1 and 3 have the videos...
In YouTube what you can do is go to Embed, and then copy and paste the embed code into the "change media" area where you are changing from a photo to a video. I hope that helps.
Awesome!!! Worked like a charm!
A quick follow up question…. Is there any way to keep the other video links from popping up after the YouTube video ends???
Thanks again,
Eric
Hi Eric -- give this a try. The YouTube interface has changed slightly since this was written, but the option to hide related video links is still there. You just have to click "Show More" from the embedding options.
Owen
That did it…. Just what we needed!!!
Thanks for the quick responses!
Take care,
I have the same issue – I usually teach workshops in front of a big group of people, and it is embarrassing to see the “related videos” at the end when mine is done. Plus, when I embed in a story map, I don’t want these “related videos” to appear. Hence I would love to do this too but sadly do not have that choice (in Chrome):
All I have is –
· Show player controls
· Show video title and player actions
· Enable privacy-enhanced mode [?<http://www.google.com/support/youtube/bin/answer.py?answer=171780&expand=PrivacyEnhancedMode#privacy>]
Joseph
Joseph J. Kerski, Ph.D., GISP | Education Manager
Esri | 1 International Court | Broomfield CO 80021-3200 | USA
Tel 303-449-7779, ext. 1-8237 | Cell-Mobile 303-625-3925
jkerski@esri.com<mailto:jkerski@esri.com> | esri.com
Twitter: http://twitter.com/josephkerski
Joseph,
I'm not sure why you are not getting that option in the UI. I just checked and saw it in Chrome and Safari (both on a Mac). However, looking at how deselecting that option changes the embed code it looks like you just need to add ?rel=0 to your URL, so you can easily do it manually.
For example:
<iframe width="560" height="315" src="https://www.youtube.com/embed/tqOmAA0HlEM?rel=0" frameborder="0" allowfullscreen></iframe>
Hope this helps!Owen
Thanks Owen! I will just do it manually. Very good to know.
I am attempting the same thing, but even after pasting the embeded link I still get Picture Not Available in the Story map Tour, trying to embed this video for point 5. Please help
Where is the Change media field area? Cna you please provide a screenshot or example of embedded url?
Carl,
Here's a screenshot. Make sure you are chosing the "Video" option...If you leave "Picture" selected you'll see the "Picture Not Available" message if you add a video link.
Use this URL for the video you want to add. It has the URL parameter that prevents related videos from showing once the video ends. https://www.youtube.com/embed/D2Rw0SNr4io?rel=0
My settings does not show this, I used storing pics on AGOL
Carl -- Ah, ok -- unfortunately Map Tour doesn't currently support mixing videos and photos if you upload your photos to ArcGIS. If you want to use videos you'll need to find somewhere else to host your photos.
