Hi ESRI Community,
I have a field map that uses a hosted feature layer published to AGOL from ArcPro 3.3. In this layer, I have many fields with Yes and No as the only domains, some configured in Pro and some added after publishing in AGOL under the fields tab. I have set the default value of these fields in the template, and on the web browser everything appears as to be set up correctly for the mobile employees to see these fields as switches.
However, on the mobile side these fields are still appearing as combo box type questions. Would anyone know why this behavior would be occurring? Any help is appreciated. Thanks!
