Using WAB dev edition. My widgets seem to be spacing out incorrectly at certain screen sizes.
Here is the config.json:
Any ideas?
joe rodmey
You need to change all 4 of the "left": lines until you get the desired location.
Can you provide some screenshots of what you are seeing?
See inlcuded
I believe its your
"position":{ "left": 45, <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
You have a space of 100 from the select to the query but the other ones are 45 and 55 so only 10 px spacing which is why they overlap
Si I need to change the 45?
It worked. Thanks!
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
