Hi, we are looking for a way to create a mobile map package via api without installing ArcGIS Pro since the service should run in a container. Is there any way to only use our ArcGIS Enterprise installation to get the mmpk?
Hi @padmalcom
You can look into the arcpy installation in ArcGIS Enterprise for the Create mobile map package python tool
Hope this helps.
Thank you @JohnYaist1, our approach is to create a service using the arcpy package on a server that hast ArcGIS Enterprise installed. This is a bit nastly since we have to create a windows container, something on linux with a small footprint library would be cleaner but since this is a workaround until the ESRI Maps SDK can export MMPKs from the Kubernetes ArcGIS Server again, it is okay for us.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
