How do I create a square of a defined area around my points when each point has a different size (see attached file)? My aim is to show the plot size on a map and colour it to show differences in the amount of carbon stored...
Thanks a lot for your help!
You can use some Python code to accomplish this. Sample code can be found here for a similar problem: https://community.esri.com/thread/84853
I'm not into Python yet, but I'll have a look. Thanks!
It is not that complex, if necessary I can explain the code or create a small toolbox from it to make it easier to use.
A small toolbox would be perfect! Could you be so kind to create one? Thanks a lot in advance. Paul
Question: Do you have ArcGIS Pro or ArcMap and what version do you have?
I have attached a 10.6 version of the toolbox.
And this is the result:
It is very likely that you don't have 10.6 (yet) since it was released last week. In that case you can construct the toolbox in your version, using the .py that you can find in the ZIP attached.
In case you have any problems just let me know and I will include a description of how to configure the toolbox for your version.
Wow, that looks perfect! Sorry I only have ArcMap 10.5 and furthermore I cannot find the attachment in your post. Sorry to cause so many problems 😕
