How do I create a square of a defined area around my points when each point has a different size (see attached file)? My aim is to show the plot size on a map and colour it to show differences in the amount of carbon stored...
Thanks a lot for your help!
You can use some Python code to accomplish this. Sample code can be found here for a similar problem: https://community.esri.com/thread/84853
I'm not into Python yet, but I'll have a look. Thanks!
It is not that complex, if necessary I can explain the code or create a small toolbox from it to make it easier to use.
A small toolbox would be perfect! Could you be so kind to create one? Thanks a lot in advance. Paul
Question: Do you have ArcGIS Pro or ArcMap and what version do you have?
