Were you able to get the code you posted to work? The script runs successfully but no parcel is selected so the map does not zoom to the selected parcel. I copied your code exactly as you posted it and I'm still not successful. I also tried including the "parse first paramter to numeric" suggestion as mentioned on 8/16/2011 but then I get an error that that it cannot concatenate 'str' and 'int' objects.
Attached is a zip file containing a portion of the parcel shapefile. Here is the code I was using to just try to test the Select by Attributes function:#Select by Attributesarcpy.env.workspace ="C:\PreApp Maps"arcpy.MakeFeatureLayer_management("Parcels.shp", "parcels_lyr")whereClause = "\"ADDRNO\" = 2 AND \"ADDRSTREET\" = 'PONDEROSA' AND \"ADDRSUFFIX\" = 'LANE'"arcpy.SelectLayerByAttribute_management ("parcels_lyr", "NEW_SELECTION", whereClause)Ideally, I would like to use 3 user defined parameters to get the parcel selected which I have been using this script that doesn't work:# Script argumentsPAR1 = arcpy.GetParameterAsText(0)PAR2 = arcpy.GetParameterAsText(1)PAR3 = arcpy.GetParameterAsText(2)#Parse first parameter to numericPAR1_int =int(PAR1) #Select by Attributesarcpy.env.workspace ="C:\PreApp Maps"arcpy.MakeFeatureLayer_management("Parcels.shp", "parcels_lyr")whereClause = "ADDRNO = PAR1_int AND ADDRSTREET = PAR2 AND ADDRSUFFIX = PAR3" arcpy.SelectLayerByAttribute_management ("parcels_lyr", "NEW_SELECTION", whereClause)
PAR1 = arcpy.GetParameterAsText(0) PAR2 = arcpy.GetParameterAsText(1) PAR3 = arcpy.GetParameterAsText(2) #Select by Attributes arcpy.env.workspace ="C:\PreApp Maps" arcpy.MakeFeatureLayer_management("Parcels.shp", "parcels_lyr") whereClause = "ADDRNO =" + PAR1 +" AND ADDRSTREET = '"+ PAR2+"' AND ADDRSUFFIX ='" + PAR3 +"'" arcpy.SelectLayerByAttribute_management ("parcels_lyr", "NEW_SELECTION", whereClause)
whereClause = "\"ADDRNO\" = " + str(PAR1_int) + " AND \"ADDRSTREET\" = '" + str(PAR2) + "' AND \"ADDRSUFFIX\" = '" + str(PAR3) +"'"
You will either need to escape your double-quotes with backslashes or single-quotes. Backslashes are probably the most obvious:"\"ADDRNO\" = 2 AND \"ADDRSTREET\" = 'PONDEROSA' AND \"ADDRSUFFIX\" = 'LANE'"
have you tested the query through the standard select by attributes interface in ArcMap? Have you tried it incrementally (ie add one piece, then the second etc)?
Thanks for the suggestion. When I tried it, I got a new error:<class 'arcgisscripting.ExecuteError'>: Failed to execute. Parameters are not valid.ERROR 000825: The value is not a layer or table viewERROR 000840: The value is not a Raster Layer.ERROR 000840: The value is not a Mosaic Layer.Failed to execute (SelectLayerByAttribute).Failed to execute (TestAddressZoomTo).Any other suggestions? Again, I am trying to select 3 address fields and zoom to the selected feature. The first field is numeric, the other 2 fields are text. I also tried changing the script so that the 3 fields were user defined parameters. Then I used the GetParameterAsText function within the SelectLayerByAttribute where clause. I got the same error as listed above. Here is the revised script I was trying:# Script argumentsPAR1 = arcpy.GetParameterAsText(0)PAR2 = arcpy.GetParameterAsText(1)PAR3 = arcpy.GetParameterAsText(2)#Select by Attributesparcels = "C:\PreApp Maps\Parcels.lyr"whereClause = "ADDRNO = PAR1 AND ADDRSTREET = PAR2 AND ADDRSUFFIX = PAR3"arcpy.SelectLayerByAttribute_management (parcels, "NEW_SELECTION", whereClause) #Zoom to Selectedmxd = arcpy.mapping.MapDocument(r"Current")df = arcpy.mapping.ListDataFrames(mxd, "Boulder County")[0]df.zoomToSelectedFeatures()#arcpy.RefreshActiveView()
arcpy.env.workspace ="C:\PreApp Maps" arcpy.MakeFeatureLayer_management("Parcels", "lyr") ... arcpy.SelectLayerByAttribute_management ("lyr", "NEW_SELECTION", whereClause)
whereClause = "ADDRNO = 1930 AND ADDRSTREET = 'BIG OWL' AND ADDRSUFFIX = 'ROAD'"
Writing a python script and attempting to use the SelectLayerByAttribute_management command.I've tried it several different ways and keep getting a syntax error on the variable set, or if the variable set works, get invalid expression. I am querying against a file geodatabase.python snippet:where_clause = (r"Status = 'U'")arcpy.SelectLayerByAttribute_management("Crimes", "NEW_SELECTION", where_clause)I'd like to add .outputCount to this to see if there are any rows selected. I have done this once in the python window but can't remember how I did it now and didn't put it in my script when it worked.I've also tried various ways of putting quotes and single quotes with and without the r or the parenthesis. Syntax error or it doesn't get passed properly to the query and gives the Invalid expression.Help!Forgot to add: In the ArcMap window using the Select by Attributes dialog, the proper syntax is "Status" = 'U' and it works as expected. Just can't get the translation to python to work properly.
arcpy.SelectLayerByAttribute_management("Crimes", "NEW_SELECTION", "\"Status\"='U'")
where_clause = ("Status = 'U'") arcpy.MakeFeatureLayer_management("Crimes", "Crimes_Lyr") arcpy.SelectLayerByAttribute_management("Crimes_Lyr", "NEW_SELECTION", where_clause) print arcpy.GetCount_management("Crimes_Lyr")
fld = arcpy.AddFieldDelimiters("Crimes", "Status") where_clause = (fld + " = 'U'") arcpy.MakeFeatureLayer_management("Crimes", "Crimes_Lyr") arcpy.SelectLayerByAttribute_management("Crimes_Lyr", "NEW_SELECTION", where_clause) print arcpy.GetCount_management("Crimes_Lyr")
