Hola Alex,The .adf file you have downloaded is actually a raster grid file; this can be directly brought into ArcMap. If you would like to take this file further, you are able to simply right click on it and export it to any format needed. I am including some documentation on this file type, this should assist you further. Gracias, Alex!Raster To Other Format (Conversion) http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//001200000032000000Esri Grid formathttp://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009t0000000w000000Supported raster dataset file formatshttp://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009t0000000q000000
Well no, ArcGIS Pro, version 3.2.0 does not import ADF file types from the State of Oregon lidar server. Ironically, the server is powered by ESRI.
"Failed to add data, unsupported data type. hh45121c6"
Me too, looking to use ADF files in ArcGIS Pro.
There is no mention of ADF in the "Supported raster dataset file formats" in the URL
https://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009t0000000q000000
Gwad, the more I look at it, the sadder I get. This help there is 10 years old.
Same here, how is this still an issue?
Well, they disabled ArcMap 10.2 and now no way to view ADF files.
Why no support in ArcGIS Pro?
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
