More details are needed.
Also, the "minimum" specs should be considered the absolute minimum to show a nice simple map. If you are trying to do something advanced, the "recommended" should be considered the minimum.
Does it crash on start up? (install is broken)
Does it crash when using all *.aprx 's? (ditto)
Does it crash on one project? (bad project or data)
It is only one tool?
etc etc
Thanks for your reply. it is crashing on start up. what think I need to do?. re download and install it?
You could try windows add/remove programs, select remove, then you will be given an option to "repair"
If that doesn't work, then there may be something with the installation.
If previous versions arcgis pro have been on the machine before, it is a good idea to remove them.
If that doesn't work, try a redownload
Do you have any add-ins installed that might be causing a conflict? You might try the troubleshooting section here: Manage add-ins—ArcGIS Pro | Documentation
I have upgraded my windows7 PC to Windows 10 by deleting all personal settings... So there are no add-ins. Thanks
Are you submitting the error reports with your email address? More about that process here: ArcGIS Desktop Error Reporter Learns Its Manners
Go to C:\Users\<username>\AppData\Local\ESRI\ErrorReports and attach a few of the latest .dmp files from Pro crashing. The filename contains a date-time stamp:
