Field maps designer does not work with new maps I have made.
When I open the map in fieldmaps designer the screen is blank.
Normally you would get options to configure the forms etc. But I get nothing.
Is this a bug, should I contact support?
Does the map open properly in new map viewer? If so, do you get the Form option there?
R_
I'm having the same issue. When I try to open a map made in Field Maps Designer, I get a blank page. I've opened the information page for the map via "Content", then am clicking on "Open in Field Maps Designer". The map will open in Map Viewer, but when I click on the "Forms" button, I also get a blank page.
Strangely enough, when I try to open Field Maps using the app buttons at the top my account page, I also get a blank page.
All worked well previously. Data was collected via Field Maps without a problem. That data shows up when the map is opened in Map Viewer. I just can't access the form to make some edits.
Perhaps Field Maps is just unavailable right now?
Same issue,
also can not open older maps
For me, the same task opened in Microsoft edge instead of Google Chrome runs fine, so try to change your browser
update chrome
