A glance of upcoming new features in Experience Builder in ArcGIS Online February release late this week. More capabilities are migrated from Web AppBuilder to Experience Builder.
Cheers,
Hello @Jianxia thank you for the updates. I am finding the micro updates, such as being able to re-order and search layers at runtime as you note above, are having a significant positive impact on our end users. Are you able to provide an update on which version of ArcGIS Enterprise these updates will be applied to?I presume 11.3 . Do you have any guidance on when 11.3 will become availalbe?
Kind regards.
Pat
@bpaton, you are right. ArcGIS Enterprise 11.3 will pick up features from ArcGIS Online February release. ArcGIS Enterprise 11.3 on Windows /Linux currently is planned to be available in late May. Thanks for sharing!
Hi @Jianxia , those features became avaiable in the experience builder developer edition following to ArcGOL or we have to wait ?
@JasonBOCQUET , yes, these features will be available in the developer edition 1.14 on March 20.
@Jianxia thanks for your reply. I have a question about Group Filter.
It is a filter applied to multiple layer or it's a filter applied to one or many layers and other layers that have a common ID are filtered too depending on the remaining elements after the filter ?
because it's not the same logic; on the first logic, all of the data have to be with the same structure or one of the filter doesn't work on one of the layer.
in the second logic you can have a filter on only one layer, and in function of what is filtered, the other layers with a common ID are filtered too.
What logic it is ?
Hi @Jianxia
Thank you for this helpful update. Will the url parameters be integrated into the Share widget for this release, or will that come later?
Samara
@WorcesterGTSS , there is a new app settings on the left so you can set time zone, favicon, thumbnail, and managing URL parameters. Once these parameters are toggled on, the Short URL on the Share widget will automatically pick them up. Unlike WAB, the URL parameter UI settings are in the app settings but the Share widget. At runtime, you can either use the URL from the Share widget or copy the app URL directly from the browser.
Fantastic! Thank you for the quick response!
Hi @Jianxia,
Question: will there be any updates to the Map Widget so that if a feature is selected via the Search Widget or Query Widget, that feature will be highlighted in the Map Widget? There is a mention of the new "Select" widget, but I am unsure if this will also interact with the Search Widget...
Thanks!
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und mehr. Neu hier? Registrieren Sie ein kostenloses Konto.
