Hi Brains TrustMy custom map A4 layout is not showing my embedded logo. My Enterprise is 11.1 and these are things I've tried:I'm publishing the tool using the "copy all data" option
Update 2: I copied the project file and templates over to the server itself. Registered the folder in server manager. When I analyse the tool before publishing it still said the folder was not registered (?!?) and was going to be copied over. But somehow that worked!
And used Pro 3.1.4
We are having the same issue in 11.1 and haven't found a fix either...
Best regards,
Gilles
Hey Dustin
I just have a few questions on this
Has this previously worked before, perhaps on a earlier version of Enterprise?
Has the machine been fully patched?
Have you tried doing this with custom print templates that are hosted on the Enterprise machine?
Many thanks,
David
Hi David
We're about rollout Enterprise to the organisation so this was our first custom print template.
All patching is up to date.
I suppose the last thing to test now is having it on the machine itself.
UPDATE: ESRI support came back with the suggestion of using a specific version of Pro.
Apparently Pro 3.1 is meant for Enterprise 11.1
I tried that but still no luck. Here's my response to them:
I also deleted the other attempts and started fresh but still no luck (see printerror jpg. When I analysed the GP tool it gave no errors but printing from Portal still failed. I checked the logs and it had this message see serverlog jpg.Not sure why it's saying value is not a member because PDF and JGP are definitely in the list when I published it.
so I'm not alone then. That's a relief at least (but sorry you are struggling with it too)
When you say copied the project file, are you referring to the .pagx files? Because I copied those to the c drive of the server and on c drive of my local computer. I was able to register the folder in the datastore and publish as reference registered data. But I still cannot get logo to appear. Am I missing another file I need to copy over to the server?
so I copied the entire Pro aprx file and published it from the server. not just the pagx file. Did you also attach the result of "Get Templates Info" tool when publishing?
And to really appease the universe I even renamed the layout object for the picture to 'Logo' 🙂
Ah, ok. So do you have Pro installed on your server?
can you help me in the custom print experience builder widget . print preview is not showing for my custom print select , if i change it to map only or any other like a-4 portrait it is working . i want to have print preview for my custom print service custom template . please help me in this .
I usually stored the templates only (.pagx) in a registered Data Store (so the ArcGIS Server service account has access to them). Same thing with the logos (they are not embedded in the templates, they are just referenced to a folder that the ArcGIS Server service account also has access to).
Hello,
I'm checking to see if this issue persists with Enterprise 11.3? I have followed the steps listed for publishing the GP Print Service on the machine that hosts the server and published it with Pro 3.3, but the logo still does not show.
