What is the timeline for Field Maps releases that will support editing the Utility Network while connected.
What is the timeline disconnected viewing and editing?
Hi @FenuxLabs
We are currently assessing the editing workflows organizations would like to achieve in the field with the Utility Network. This is a high priority item which we are working on but do not have a release date set. We will be sharing this as soon as we can but to set expectations it will not be until 2024.
Would you be open to sharing your use cases for editing? If yes let me know and I'll send through details for us to talk further.
Use Cases:
Thanks Ben. Is that in prioritized order? To clarify you see the team in the field:
What devices would the teams typically use, phones, tablets, laptops? Would your team typically be working with point features?
I'd like to add that for our organization, we like to restrict field edits to updating a few selected fields and adding/deleting attachments. We didn't allow field users to add or delete features or update geometries with our Geometric Network data, and we were able to publish services that let us lock things down this way. The Utility Network currently requires all editing options be turned on when you publish.
JC - You can set the services to limit users options. In Server Manager click on the service and go to Capabilities - Feature Access.
You can then check or uncheck the ones you want.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
