When I use the search widget in my EB map, it will auto select and pan/zoom/flash the polygon I want based on the search criteria. The other thing it does is it filters the data and hides all of the other non-selected features until I click the "X" and wipe out the search criteria. I really need it to NOT filter/un-show the non-selected features and continue to select/flash the one I searched for. Is this possible? I can't find a setting anywhere in the widget that controls this.
This was added in Experience Builder 1.12, equivalent to Enterprise 11.2.
Toggle this setting off seems to do that.
R_
I'm guessing that's something they've added in the newer version on AGOL. I'm using the enterprise version, so it doesn't appear to be an option:
Anyone know if you can add a marker when using the search widget, I know it has it if you use the standard search?
I think you will need to make a copy of the search widget and add the code yourself.
The standalone Search Widget does not need to be used with a Map Widget and it is possible to use it on a feature without geometry, so that is probably why the marker is not a default option.
