If you pass along the JSON generated by your request, I can have a look and figure out what's wrong.
I think I need more specifics on exactly what doesn't work. I can see that the graphics layers are read correctly (they show some features in southern Texas), but many of them appear to have alpha values of 0 in the color definitions. For example, the outlines in your middle graphics layer. Those are treated as null colors in the output. Is that the problem -- that the graphics layers don't appear in your output?
I need to see the Python code.
Yes that is the issue. The black back ground color is used as default since alpha values of 0 in the color definitions. Whta is your solution to fix it? Thanks, George
1. dose not support a polygon with a transparency2. dose not support a point with ESRI.ArcGIS.Client.Symbols.TextSymbol3. mix of geometry types
2. does not support a point with ESRI.ArcGIS.Client.Symbols.TextSymbol
Layer "graphicsLayer1": Field 'newID' not part of schema for this feature collection.
import json jsonMap = json.loads(webMapAsJson) # -- so you can manipulate the json if jsonMap.has_key("operationalLayers"): # -- to get in the operational layer array : for operationalLayer in jsonMap["operationalLayers"]: #-- for each operational layer : if operationalLayer.has_key("featureCollection"): #-- That would be a graphicsLayer modifyTransparencyInGraphicsLayers(operationalLayer) # -- Send to a function to modify the json (this remove transparency in my case) outputJson = json.dumps(jsonMap ) # -- then you reencode your jsonMap to json result = arcpy.mapping.ConvertWebMapToMapDocument(outputJson , templateMxd) # -- Finally you can get back to the method described in the tutorial def modifyTransparencyInGraphicsLayers(operationalLayer): # -> Modify Tranparency for 'GraphicLayers' if operationalLayer["featureCollection"].has_key("layers"): for operationalLayersGraphicsLayerLayer in operationalLayer["featureCollection"]["layers"]: if operationalLayersGraphicsLayerLayer.has_key("featureSet"): if operationalLayersGraphicsLayerLayer["featureSet"].has_key("features"): for graphicsLayerParams in operationalLayersGraphicsLayerLayer["featureSet"]["features"]: if graphicsLayerParams.has_key("symbol"): if graphicsLayerParams["symbol"].has_key("color"): if len(graphicsLayerParams["symbol"]["color"]) == 4: graphicsLayerParams["symbol"]["color"][3] = 255 if graphicsLayerParams["symbol"].has_key("outline"): if graphicsLayerParams["symbol"]["outline"].has_key("color"): if len(graphicsLayerParams["symbol"]["outline"]["color"]) == 4: graphicsLayerParams["symbol"]["outline"]["color"][3] = 255 return operationalLayer
Hi,Has there been a definitive listing of the limitations of Export Web Map yet?Specifically, I'm having trouble exporting a map that contains a graphics layer symbolized using a unique value renderer.I'm getting a similar error: Error executing tool.: Layer "graphicsLayer2": Field 'pointType' not part of schema for this feature collection. Where the field 'pointType' contains the value to be rendered on.Thanks!Jill
Jill, did you ever resolve this? I'm experiencing the same problem. Steve
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
