Is this possible in ExB apps? An example of this is - If I click on a containment (say a switching station) then can I design the pop-up to display all switches associated as related items in the pop-up?
@RobertKrisher
I agree with what @ChristopherCounsell said, this is currently not possible out of the box (both lines and the popups) so it's something you'd need to do with custom JavaScript.
This exists as an ArcGIS Idea:
https://community.esri.com/t5/arcgis-utility-network-ideas/show-associations-in-a-web-map-arcgis-online-and/idc-p/1181655#M173
It seems like it's only possible with custom JavaScript at this time.
https://developers.arcgis.com/javascript/latest/utility-network/associations/
@ChristopherCounsell - Thanks for the links. I understand you can view associations as dotted lines but I am wondering if its possible showing the associations in the pop-up. You can use arcade to pull some stats but it doesn't have the same effect as you would when you add related records in the pop-up. Like I said - I want to be able to click on a container and at the end of the pop-up you'd be able to see all the (related/associated) records. Spatial and Non-Spatial records
