Hi
We have Arcgis Enterprise 10.8.1 with Oracle geodatabase.
It has several user-schema geodatabases with existing database users.
I want to move the data from the user-schema geodatabases into the sde geodatabase.
From arcgis pro , I connected to userschema geodatabase as a schema user. and connected to sde schema as a sde user.
Can I copy data from user-schema geodatabases and paste into the sde geodatabase.
Is this process correct?
If I have ABC user with ABC schema. I just copy the data into SDE schema. and then assign the privileges to ABC user?
I find the esri documentation confusing. why esri doesn’t make it clear ?
why there is a need to create a new database user if one already exists ?
If there is no user schema , how do we distinguish between different users or type of data?
How does users access their data only and not being able to edit others data?
Is there any issues with all the users data owned by SDE?
Thanks
