Why does my attached image not show within my Pop-up? The image is there it requires me to download the image.
I have performed this before with success and the image shows within the Pop-up.
In the popup config, do you have the "Display Attachments As" set to Gallery?
R_
Thank you so much for responding, yes I have "Gallery" set.
Hey Walter,
Is this happening on numerous images or just this one in particular? Could we confirm the image format as well?
Many thanks,
David
Was there any solution here? I am experiencing the same issues. Geodatabase attachment images (.jpg) included with the layer when shared through Pro only show as links even when in Gallery mode. If I add additional images through AGOL those will show up correctly as inline images.
I have similar issue. My data are referenced from enterprise geodatabase. It has problem in pop-up at Portal and AGOL and in Feature Info widget in ExB.
Here is image, how it looks like:
In ArcGIS Pro it works correctly:
And it also display great in Image Widget in ExB:
Do anybody know about solution or workaround?
Was anyone able to fix this?
There is a problem with maximum size of image. I could not find it now, but I think it was 10 MB for pop-up. It is same for Feature Info because Feature Info is only different view to Pop-up.
So you can:
