<?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><soap:Body><soap:Fault><faultcode>soap:Server</faultcode><faultstring>Server was unable to process request. ---> The request failed with HTTP status 404: Service Not Found or Not Started.</faultstring><detail /></soap:Fault></soap:Body></soap:Envelope>
if (ArcGISDynamicMapServiceLayer(liveLayers).id != "Aerial Photography")
Jason, Open a web browser and test if the web service is doing what it is suppose to. So on the ArcGIS Server machine that you ran the setup on type "http://localhost/restLegend/restLegend.asmx" and then click on generateLegends and type in some default values like:soapUrl: http://services.arcgisonline.com/ArcGIS/services/Demographics/ESRI_Diversity_US_2D/MapServerdpi: 96pWidth: 20pHeight: 20serviceName: TestThat should return a XML result.
