Justin, Time to attach your button click code then.
Justin, Sorry I meant that I want you to attach your button click code that you are using for me to look at.
<?xml version="1.0" encoding="utf-8"?> <viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:viewer="com.esri.viewer.*"> <fx:Script> <![CDATA[ import com.esri.ags.geometry.MapPoint; import com.esri.ags.utils.WebMercatorUtil; import mx.controls.Alert; private function createPermalink():void { var currentCenter:MapPoint = WebMercatorUtil.webMercatorToGeographic(map.extent.center) as MapPoint; navigateToURL(new URLRequest( "index.html?center=" + myDegreeFormatter.format(currentCenter.y) + "," + myDegreeFormatter.format(currentCenter.x) + "&scale=" + Math.round(map.scale)), "_blank"); } private function getURLParameters():Object { var result:URLVariables = new URLVariables(); try { if (ExternalInterface.available) { // Use JavaScript to get the search string from the current browser location. // Use substring() to remove leading '?'. // See http://livedocs.adobe.com/flex/3/langref/flash/external/ExternalInterface.html var search:String = ExternalInterface.call("location.search.substring", 1); if (search && search.length > 0) { result.decode(search); } } } catch (error:Error) { Alert.show(error.toString()); } return result; } private function setMapLocation():void { var params:Object = getURLParameters(); if (params["ll"]) { var latlong:Array = String(params.ll).split(","); if (latlong.length == 2) { map.centerAt(WebMercatorUtil.geographicToWebMercator(new MapPoint(latlong[1], latlong[0])) as MapPoint); } } if (params["scale"]) { map.scale = params.scale; } } ]]> </fx:Script> <fx:Declarations> <mx:NumberFormatter id="myDegreeFormatter" precision="6" useThousandsSeparator="true"/> </fx:Declarations> <viewer:WidgetTemplate id="passURL" widgetTitle="Pass URL" width="200" height="100"> <s:HGroup id="groupURL"> <s:Button click="createPermalink()" fontSize="14" fontWeight="bold" label="Create a hyperlink"/> </s:HGroup> </viewer:WidgetTemplate> </viewer:BaseWidget>
<?xml version="1.0" encoding="utf-8"?> <viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:viewer="com.esri.viewer.*"> <fx:Script> <![CDATA[ import com.esri.ags.geometry.MapPoint; import com.esri.ags.utils.WebMercatorUtil; import mx.controls.Alert; private function createPermalink():void { var currentCenter:MapPoint = (map.extent.center) as MapPoint; navigateToURL(new URLRequest( "index.html?center=" + myDegreeFormatter.format(currentCenter.x) + "," + myDegreeFormatter.format(currentCenter.y) + "&scale=" + Math.round(map.scale)), "_blank"); } private function getURLParameters():Object { var result:URLVariables = new URLVariables(); try { if (ExternalInterface.available) { // Use JavaScript to get the search string from the current browser location. // Use substring() to remove leading '?'. // See http://livedocs.adobe.com/flex/3/langref/flash/external/ExternalInterface.html var search:String = ExternalInterface.call("location.search.substring", 1); if (search && search.length > 0) { result.decode(search); } } } catch (error:Error) { Alert.show(error.toString()); } return result; } private function setMapLocation():void { var params:Object = getURLParameters(); if (params["ll"]) { var latlong:Array = String(params.ll).split(","); if (latlong.length == 2) { map.centerAt(new MapPoint(latlong[1], latlong[0])); } } if (params["scale"]) { map.scale = params.scale; } } ]]> </fx:Script> <fx:Declarations> <mx:NumberFormatter id="myDegreeFormatter" precision="0" useThousandsSeparator="false"/> </fx:Declarations> <viewer:WidgetTemplate id="passURL" widgetTitle="Pass URL" width="200" height="100"> <s:HGroup id="groupURL"> <s:Button click="createPermalink()" fontSize="14" fontWeight="bold" label="Create a hyperlink"/> </s:HGroup> </viewer:WidgetTemplate> </viewer:BaseWidget>
var request:URLRequest = new URLRequest("mailto:someone@gmail.com?subject=Map Link&body=index.html?center=" + myDegreeFormatter.format(currentCenter.x) + "," + myDegreeFormatter.format(currentCenter.y) + "&scale=" + Math.round(map.scale)) navigateToURL(request,"_blank");
var u:URLRequest=new URLRequest ("mailto:someone@gmail.com?subject=Map Link&body=http://gis.co.wood.wi.us/Flex24/index.html?center=" + myDegreeFormatter.format(currentCenter.x) + "," + myDegreeFormatter.format(currentCenter.y) + "&" + "scale=" + Math.round(map.scale)) navigateToURL(u,"_self");
var u:URLRequest=new URLRequest ("mailto:someone@gmail.com?subject=Map Link&body=http://gis.co.wood.wi.us/Flex24/index.html?center=" + myDegreeFormatter.format(currentCenter.x) + "," + myDegreeFormatter.format(currentCenter.y) + "%26" + "scale=" + Math.round(map.scale)) navigateToURL(u,"_self");
<?xml version="1.0" encoding="utf-8"?> <viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:viewer="com.esri.viewer.*"> <fx:Script> <![CDATA[ import com.esri.ags.geometry.MapPoint; import com.esri.ags.utils.WebMercatorUtil; import mx.controls.Alert; private function mailme():void { var currentCenter:MapPoint = (map.extent.center) as MapPoint; var u:URLRequest=new URLRequest ("mailto:someone@gmail.com?subject=Map Link&body=http://gis.co.wood.wi.us/Flex24/index.html?center=" + myDegreeFormatter.format(currentCenter.x) + "," + myDegreeFormatter.format(currentCenter.y) + "%26" + "scale=" + Math.round(map.scale)) navigateToURL(u,"_self"); } private function getURLParameters():Object { var result:URLVariables = new URLVariables(); try { if (ExternalInterface.available) { // Use JavaScript to get the search string from the current browser location. // Use substring() to remove leading '?'. // See http://livedocs.adobe.com/flex/3/langref/flash/external/ExternalInterface.html var search:String = ExternalInterface.call("location.search.substring", 1); if (search && search.length > 0) { result.decode(search); } } } catch (error:Error) { Alert.show(error.toString()); } return result; } private function setMapLocation():void { var params:Object = getURLParameters(); if (params["ll"]) { var latlong:Array = String(params.ll).split(","); if (latlong.length == 2) { map.centerAt(new MapPoint(latlong[1], latlong[0])); } } if (params["scale"]) { map.scale = params.scale; } } ]]> </fx:Script> <fx:Declarations> <mx:NumberFormatter id="myDegreeFormatter" precision="0" useThousandsSeparator="false"/> </fx:Declarations> <viewer:WidgetTemplate id="passURL" widgetTitle="Pass URL" width="200" height="100"> <s:HGroup id="groupURL"> <s:Button click="mailme()" fontSize="14" fontWeight="bold" label="Email Map Link"/> </s:HGroup> </viewer:WidgetTemplate> </viewer:BaseWidget>
http://http://servername/FlexViewer/v23/idea/PAidea/MainProjectv231/index.html?config=config-Basic.xml¢er=-8382590,4857620&scale=9028
<?xml version="1.0" encoding="utf-8"?> <viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:viewer="com.esri.viewer.*"> <fx:Script> <![CDATA[ import com.esri.ags.geometry.MapPoint; import com.esri.ags.utils.WebMercatorUtil; import mx.controls.Alert; [Bindable] private var EmailComment:String; // Sends data to email file // Ref: http://forums.arcgis.com/threads/41459-Create-Email-with-Hyperlink-to-share-map-extent // Ref: http://stackoverflow.com/questions/6841136/mailto-with-attachments-in-flex-or-air-applications // Ref: http://zoomquiet.org/res/scrapbook/ZqSKM/data/20100419224556/ private function mailme():void { var currentCenter:MapPoint = (map.extent.center) as MapPoint; var u:String = ""; u+= "mailto:mappers@site.com"; u+= "?"; u+= "subject="; u+= emailSubject.text; u+= " "; u+= "&body=http://url/siteweb/?center=" + myDegreeFormatter.format(currentCenter.x) + "," + myDegreeFormatter.format(currentCenter.y) + "%26" + "scale=" + Math.round(map.scale) + "%0D%0A" + "%0D%0A" //Creates two blank lines + emailComment.text; var url:URLRequest= new URLRequest(u); navigateToURL(url); } private function getURLParameters():Object { var result:URLVariables = new URLVariables(); try { if (ExternalInterface.available) { // Use JavaScript to get the search string from the current browser location. // Use substring() to remove leading '?'. // See http://livedocs.adobe.com/flex/3/langref/flash/external/ExternalInterface.html var search:String = ExternalInterface.call("location.search.substring", 1); if (search && search.length > 0) { result.decode(search); } } } catch (error:Error) { Alert.show(error.toString()); } return result; } private function setMapLocation():void { var params:Object = getURLParameters(); if (params["ll"]) { var latlong:Array = String(params.ll).split(","); if (latlong.length == 2) { map.centerAt(new MapPoint(latlong[1], latlong[0])); } } if (params["scale"]) { map.scale = params.scale; } } ]]> </fx:Script> <fx:Declarations> <mx:NumberFormatter id="myDegreeFormatter" precision="0" useThousandsSeparator="false"/> </fx:Declarations> <viewer:WidgetTemplate id="passURL" widgetTitle="Pass URL" width="100%" height="100%"> <s:VGroup id="groupURL"> <s:Label text="Subject: "/> <s:TextInput id="emailSubject"/> <s:Label text="Comment: "/> <s:TextArea id="emailComment" maxChars="250"/> <s:Button click="mailme()" fontSize="12" fontWeight="bold" label="Report Error"/> </s:VGroup> </viewer:WidgetTemplate> </viewer:BaseWidget>
<?xml version="1.0" encoding="utf-8"?> <viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:viewer="com.esri.viewer.*"> <fx:Script> <![CDATA[ import com.esri.ags.geometry.MapPoint; import com.esri.ags.utils.WebMercatorUtil; import mx.controls.Alert; private function mailme():void { var currentCenter:MapPoint = (map.extent.center) as MapPoint; var u:String = ""; u+= "mailto:email@address.com"; u+= "?"; u+= "subject="; u+= emailSubject.text; u+= " "; u+= "&body=http://my_url/index.html?center=" + myDegreeFormatter.format(currentCenter.x) + "," + myDegreeFormatter.format(currentCenter.y) + "%26" + "scale=" + Math.round(map.scale) + "%0D%0A" + "%0D%0A" //Creates two blank lines + emailComment.text; var url:URLRequest= new URLRequest(u); navigateToURL(url, "_self"); } private function getURLParameters():Object { var result:URLVariables = new URLVariables(); try { if (ExternalInterface.available) { // Use JavaScript to get the search string from the current browser location. // Use substring() to remove leading '?'. // See http://livedocs.adobe.com/flex/3/langref/flash/external/ExternalInterface.html var search:String = ExternalInterface.call("location.search.substring", 1); if (search && search.length > 0) { result.decode(search); } } } catch (error:Error) { Alert.show(error.toString()); } return result; } private function setMapLocation():void { var params:Object = getURLParameters(); if (params["ll"]) { var latlong:Array = String(params.ll).split(","); if (latlong.length == 2) { map.centerAt(new MapPoint(latlong[1], latlong[0])); } } if (params["scale"]) { map.scale = params.scale; } } ]]> </fx:Script> <fx:Declarations> <mx:NumberFormatter id="myDegreeFormatter" precision="0" useThousandsSeparator="false"/> </fx:Declarations> <viewer:WidgetTemplate id="passURL" widgetTitle="Pass URL" width="100%" height="100%"> <s:VGroup id="groupURL"> <s:Label text="Subject ID: "/> <s:TextInput id="emailSubject" width="300"/> <s:Label text="Comment: "/> <s:TextArea id="emailComment" width="300" height="400" text ="I have a question."/> <s:Button click="mailme()" fontSize="14" fontWeight="bold" label="Email Us"/> </s:VGroup> </viewer:WidgetTemplate> </viewer:BaseWidget>
Arthur, The mailto handling is browser specific and can be altered by the end users preference changes in the browser or a corporations IT restrictions. The user can change how mailto: links behave in chrome by visiting chrome://settings/handlers, or Chrome Settings->Content Settings->Manage Handlers...
Arthur, I am not a big Chrome fan so I don't know any more than what I Google on the net.
