I have gotten a use case where if button in an Addin UI is missing somehow I have to disable other functionalities. So basically if that button is not visible in the UI then how to disable other functionalities dependent on that button because I don't want user to use those functionalities.
Any help!
@Wolf @GKmieliauskas @CharlesMacleod
1. Create new condition in module daml
2. Deactivate created condition in add-in module Initialize method
protected override bool Initialize() { FrameworkApplication.State.Deactivate("your_condition_name"); }
3. In your specific button constructor activate created condition
public YourSpecificButton() { FrameworkApplication.State.Activate("your_condition_name"); }
4. Add condition to related tools in daml
Can you elaborate why a button would be missing from the UI? Is the Add-in not installed ? If the Add-in is installed why would the button be missing? I don't understand your use case for this.
Yes Addin not installed can be an only use case I can think of.
@Wolf
@GKmieliauskas is quite correct as you need to implement your own states and conditions to control your Add-in's UI. There is a ProGuide to states and conditions here: ProGuide Code Your Own States and Conditions · Esri/arcgis-pro-sdk Wiki (github.com)
Then in your add-in's module class you can check for the existence of the needed Add-in using the FrameworkApplication API:
var theNeededModule = FrameworkApplication.FindModule("NeededModule");
The Module ID "NeededModule" can be found in the Add-in module's config.daml file:
... <modules> <insertModule id="NeededModule" className="Module1" autoLoad="false" ...>
If theNeededModule value is null the needed add-in is not available otherwise the needed add-in is available. You can use that value to control your states and conditions.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
