Was hoping someone can show me how to add the opacity slider to a layer list with legend.
I am essentially trying to combine these two examples. preferably adding action items to the layer list with legend example.
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=widgets-layerlist-legend
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=widgets-layerlist-actions
In the Add a Legend to LayerList sample, you can add an opacity slider by changing the contents of the script tag beginning on line 32 to the following:
require(["esri/WebMap", "esri/views/MapView", "esri/widgets/LayerList", "esri/widgets/Slider"], ( WebMap, MapView, LayerList, Slider ) => { const map = new WebMap({ portalItem: { id: "d5dda743788a4b0688fe48f43ae7beb9" } }); // Add the map to a MapView const view = new MapView({ container: "viewDiv", map: map }); async function defineActions(event) { const item = event.item; await item.layer.when(); if (item.title === "Census Tracts") { const slider = new Slider({ min: 0, max: 1, precision: 2, values: [1], visibleElements: { labels: true, rangeLabels: true } }); item.panel = { content: ["legend",slider], open: true, className: "esri-icon-sliders-horizontal", title: "Layer Info" }; slider.on("thumb-drag", (event) => { const { value } = event; item.layer.opacity = value; }); } } // Add a legend instance to the panel of a // ListItem in a LayerList instance const layerList = new LayerList({ view: view, listItemCreatedFunction: defineActions }); view.ui.add(layerList, "top-right"); });
Thank you for taking a look!
Your code appears to add the opacity slider but removes the legend items. Below is the code snippet I am using to add the legend to layer list. I'm not sure how to add the slider event to the existing event.
// create a layerlist and expand widget and add to the view const layerList = new LayerList({ view: view, listItemCreatedFunction: (event) => { const item = event.item; if (item.layer.type != "group") { // don't show legend twice item.panel = { content: "legend", open: false }; } } }); const llExpand = new Expand({ view: view, content: layerList, expanded: false }); view.ui.add(llExpand, { position: "top-left", index: 0 });
If by "legend items" you mean "action items", then perhaps this is what you're looking for:
require(["esri/WebMap", "esri/views/MapView", "esri/widgets/LayerList", "esri/widgets/Slider"], ( WebMap, MapView, LayerList, Slider ) => { const map = new WebMap({ portalItem: { id: "d5dda743788a4b0688fe48f43ae7beb9" } }); // Add the map to a MapView const view = new MapView({ container: "viewDiv", map: map }); async function defineActions(event) { const item = event.item; await item.layer.when(); if (item.title === "Census Tracts") { const slider = new Slider({ min: 0, max: 1, precision: 2, values: [1], visibleElements: { labels: true, rangeLabels: true } }); item.panel = { content: ["legend",slider], open: true, className: "esri-icon-sliders-horizontal", title: "Layer Info" }; slider.on("thumb-drag", (event) => { const { value } = event; item.layer.opacity = value; }); item.actionsSections = [ [ { title: "Go to full extent", className: "esri-icon-zoom-out-fixed", id: "full-extent" }, { title: "Layer information", className: "esri-icon-description", id: "information" } ], [ { title: "Increase opacity", className: "esri-icon-up", id: "increase-opacity" }, { title: "Decrease opacity", className: "esri-icon-down", id: "decrease-opacity" } ] ]; } } // Add a legend instance to the panel of a // ListItem in a LayerList instance const layerList = new LayerList({ view: view, listItemCreatedFunction: defineActions }); layerList.on("trigger-action", (event) => { // The layer visible in the view at the time of the trigger. const visibleLayer = event.item.layer; // Capture the action id. const id = event.action.id; if (id === "full-extent") { // if the full-extent action is triggered then navigate // to the full extent of the visible layer view.goTo(visibleLayer.fullExtent).catch((error) => { if (error.name != "AbortError") { console.error(error); } }); } else if (id === "information") { // if the information action is triggered, then // open the item details page of the service layer window.open(visibleLayer.url); } else if (id === "increase-opacity") { // if the increase-opacity action is triggered, then // increase the opacity of the GroupLayer by 0.25 if (visibleLayer.opacity < 1) { visibleLayer.opacity += 0.25; } } else if (id === "decrease-opacity") { // if the decrease-opacity action is triggered, then // decrease the opacity of the GroupLayer by 0.25 if (visibleLayer.opacity > 0) { visibleLayer.opacity -= 0.25; } } }); view.ui.add(layerList, "top-right"); });
Thanks for taking another look. If I use the code above it removes the legend within the layer list.
