Richard,Thank you for contributing this add-in, however I cannot use it. Have installed it, turned on extension, and turned on dialog no problem. But the "Z and M Enabled Projected Layers" dropdown list remains consistently empty, even when I have perfectly good PolylineZM layers in my map that I would like to re-measure honouring the z values (i.e. in 3D). Any idea why this is happening? Using ArcGIS 10.0.5 at ArcInfo license level. Have tried polylineZM input layers that are both file GDB feature classes and shapefiles.
Richard, I have downloaded your tool and tried to use it, but clicking on the button interface of the tool, greyed out the tool and did not bring up an iterface window. I am using ArcGIS10 SP3.Thanks,Narmina
Code for Projected Coordinate Systems should work fine for me. I will double-check that my data has linear units instead of angular, if not I am fine projecting them to try out the tool. Also, my routes are all continuous and do not contain any gaps, so I won't need to worry about that functionality for now.Thanks for all of your work on this. I am very curious to try it out!
I am indeed interested in such a tool since (in my opinion) linear referencing for large-scale real world conditions is pretty much worthless without taking into account elevation. I can see the point of calibrating a route with observations (time consuming), but for regional analysis it would be great to merge the M and Z functionality.Let me know if you want someone to test your Add-In because I have a State-wide layer and I would like to see how it changes when Z-values are considered.
