Multiversioned views incorporate database views, stored procedures, triggers, and functions to access a specified version of data in a geodatabase table using Structured Query Language (SQL).
jnderose,I was thinking about my problem and using multiversioned views. Can I get by with not using a MV view if I add all of the records from that layer and did a join field in arctoolbox? I have fields that I need to delete first and then do a join field to get the data field I need filled in? Then syncronize and to update the parent. Would you need to do the schema changes first?ThanksQuinn
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
