This is good but seems like an awful lot of double, triple, quadruple+ handling as groups/custodians write down details to post elsewhere which are then copied back to providers, then eventually corrected.
Has there been any thought given to an OpenStreetMap-like system where the geometry and attributes are submitted directly, or even *shock, horror* validating basemap features against OSM itself?
Yes I realise that an open crowdsourced system is not the same as authoritative data, but could be used to test veracity/currency to give a confidence rating.
Is there a place we can submit errors specifically with the routing service such as height restrictions or one-way streets?
Like many, my issue is with the Nat Geo World Map - in particular unusual parcels in Alaska public lands. I can't find a feedback option for that one, and the issues are not on
Street map feedback map
Topographic feedback map
Imagery feedback map
I did find this - NatGeo Mapmaker Interactive - where there is a "Give Feedback" button.
Thanks!
I noticed a labeling error on the Nat Geo Basemap. In the Los Angeles Area, the University of California Los Angeles otherwise known as U.C.L.A, is labeled as neither of these. It is labeled as "University Of California-La", written in this specific case.
If the name of the city needs to abbreviated, Los Angeles is never abbreviate as "La". It can be abbreviated as "LA" in certain circumstances.
In addition, just south of the campus is the label, "Ronald Reagan Ucla Medical Ctr" Here the abbreviation "Ucla" should all be in capitols.
The two labels should be corrected and be consistent
These directions seem to be for Desktop and not Pro. I cannot figure out how to leave feedback on ArcGIS Pro.
Yes. It was Western State College of Colorado from 1923 to 2012, then Western State Colorado University from 2012 to 2018, and recently changed to Western Colorado University.
I used to live in Gunnison in the 80’s. At that time it was known as Western State College. Did it change it’s name?
In Gunnison, Colorado, the university is incorrectly labeled. It should read "Western Colorado University," but it is labeled as either "Western State Colorado University" or "Western State College" depending on zoom. We are currently working on a project for this community, so addressing this issues swiftly would be much appreciated.
I've added this comment to all 3 of the listed topics for map comments, but wanted to add it here as well, as i've found the issue on all Esri basemaps.
I've noticed two errors in the Nat Geo basemap in Montana. At 1:144,000 scale the Gallatin range is mislabeled as the Big Belts south of Hwy 12 between Bozeman and Livingston. Near 45.56849,-110.85063.
The DEER Lodge Mountains to the east of Deer Loge MT are consistently misspelled as the DEAR Lodge Mountains at every scale they appear.
In the National Geographic USA Topo Map http://goto.arcgisonline.com/maps/USA_Topo_Maps , the county in the vicinity of Alamo Lake, Arizona (roughly 34.2709° N, 113.5699° W) is incorrectly identified as Yuma County, when it is in La Paz County.
thanks tricard29
Hi Mike,
I was looking at all the different ESRI basemaps and I noticed that in Mecklenburg County located in North Carolina a creek has been labeled as Brier creek. The name of the creek is Briar creek. It would be great if you could change the name
Thanks for your help
Chattahoochee Drive in Duluth GA from Peachtree Industrial Blvd to Rogers Bridge Road needs to be renamed to Main Street per our City Council. I am the GIS Analyst for Duluth if you have any questions, mphillips@duluthga.net
I have observed a fairly big issue.
So, Esri uses our Community data in its community 100 update program for the Topographic basemap. So the Topo basemap is accurate (as of when we submitted) with our own local road centerlines and other data.
They do NOT use this data in the Streets basemap. Which we use on www.sagis.org because it "looks more like Google". Or at least, it's more out of date than the Topo basemap.
Does Esri have plans to use the correct geometry data for Streets that they do in Topo at some time in the future? Also, I have noticed when zooming out, sometimes roads disappear and old ones that no longer exist, come up. I have discussed this a few years back with Esri and they mentioned they use national vendors for scales above neighborhood level. Well.. .if that is the way it must be then, ok. I wanted to leave this here as a cautionary note to GISers. And perhaps inquire again and check in on this. Why can't our accurate local data be tiled on up the scale level the whole ways of levels of detail. The larger levels are the easiest and quickest to tile, right? I would like basemaps to use local geometry, when possible of course. Or add Google to basemaps. Just kidding. I am interested to hear from Esri folks about whether they may plan to use the accurate local data from Topo maps, in to the Streets basemaps anytime in the future? Is that on a future update roadmap? ( pun intended...)
Hi Jan, I edited you post to fix the link. The ). was included and thus an error. Should be ok now.
I posted this on the National Geographic World Map page, but thought it good to post here. National Geographic World Map is a reference map. When the view is centered on all of Alaska (8.5 x 11 " size), I see ALASKA with UNITED STATES underneath it. I don't see anything to identify Yukon or Kamchatka, nor their respective countries. When I go to a 11 by 17" size, I see YUKON, but no CANADA. Kamchatka is absent as well as any mention to the country RUSSIA. Cartographic principles are based on consistency and uniformity. Given the lack of geographic knowledge in the U.S., this is a disservice to omit the country divisions and names. I notice this on paper maps of hand-held size. If I go to a mobile device such as a phone, again I see Alaska, but no YUKON or KAMCHATKA. Cartographic principles are such that if label one division, you should label others the same way. I know you cannot label at all scales, but as a reference map, when I see a state, I should be able to the adjacent countries otherwise it might just as well be an island.
Also, why does it say Mt McKinley on the Alaska? The name was officially changed in 2015 (http://news.nationalgeographic.com/2015/08/150831-denali-mount-mckinley-name-change-geography-maps/). It needs to be updated.
As long as feedback gets to us, any method is fine. But, if you ask me to order the pathways, I'd suggest the following:
Mike
Thanks for the response. Aside from submitting data through the Community Maps Program, what would be the correct course for suggesting corrections to potential errors in the basemap data?
Thanks again,
I'll pass it on...
thanks,
I came across this thread looking for some formal way to submit corrections to basemap data for (primarily) Light Grey Canvas, although others have the similar issues since I'm assuming the source data is the same.
I live and work on Long Island, NY and here's my short list.
NY Route 135 [Seaford-Oyster Bay Expressway] and NY Route 27 [Sunrise Highway] appear to be labeled as their "dedicated" names instead of their actual names. Regular and Vector
Suffolk County Road 51 changes names partway, and the point at which it changes from Center Dr S to Moriches-Riverhead Rd is incorrect. It should be approximately Lake Ave. Regular and Vector
Suffolk County Road 75 is not part of William Floyd Parkway. It is called Fire Island Beach Road. Not in regular light grey, but it's in others as well as the Vector
http://www.greaternyroads.info/pdfs/suffcr.pdf
Wertheim National Wildlife Refuge is incorrectly labeled as Southaven Park (which is north of NYS Route 27). Additionally Southaven (insert "County")Park is unlabeled (compared to ragular basemap). Vector only
https://www.fws.gov/uploadedFiles/WRT_Trail_Map_FINAL.pdf
Wertheim National Wildlife Refuge is incorrectly labeled as Southaven Park (which is north of NYS Route 27) in addition to it's correct label. Also indicate Southaven County Park. Regular only
Fire Island National Seashore labels sometimes occur on Smith Point County Park. While I believe Fire Island National Seashore does have a say in management decisions the land area is all Smith Point County Park. Regular onlyhttps://www.nps.gov/fiis/planyourvisit/maps.htm
Westhampton House is correctly labeled on the Vector Basemaps, but the regular basemaps have multiple labels down towards Pikes Beach.
