AcroRd32 /N /T PdfFile [PrinterName [ PrinterDriver [ PrinterPort ] ] ]
import subprocess printer='MyPrinter' pdffile=r'C:\Some Dir\some pdf.pdf' acroread=r'C:\Program Files (x86)\Adobe\Reader 9.0\Reader\AcroRd32.exe' #'"%s"'is to wrap double quotes around paths # as subprocess will use list2cmdline internally if we pass it a list #which escapes double quotes and Adobe Reader doesn't like that cmd='"%s" /N /T "%s" "%s"'%(acroread,pdffile,printer) proc = subprocess.Popen(cmd,stdout=subprocess.PIPE,stderr=subprocess.PIPE) stdout,stderr=proc.communicate() exit_code=proc.wait()
# This script allows a user to input a parcel ID number # This will automatically save the map to PDF so it can be printed # Written by Caleb Mackey 9/17/2012 # Print PDF section courtesy of Luke Pinner 9/18/2012 import arcpy, os, sys, traceback import subprocess arcpy.env.overwriteOutput = True def userinput(): mxd = arcpy.mapping.MapDocument("G:\\Map_Documents\\Walkin_requests\\Customer_map.mxd") df = arcpy.mapping.ListDataFrames(mxd, "Main")[0] parcels = arcpy.mapping.ListLayers(mxd, "Parcels GIS Acres", df)[0] pdfpath = 'C:\\Documents and Settings\\gis\\Desktop\\PRINT_MAPS\\' txtfile = pdfpath + 'Parcelmap_ERROR.txt' acroread = r'C:\Program Files\Adobe\Reader 10.0\Reader\AcroRd32.exe' try: print "Enter Parcel Number WITHOUT dashes and hit ENTER" parcelid = raw_input() parcel_num = str(parcelid) print 'selecting parcel...' query = "SOL_PID ='%s'" % parcel_num arcpy.SelectLayerByAttribute_management(parcels, "NEW_SELECTION", query) result = arcpy.GetCount_management(parcels) if str(result) == '0': print 'Invalid SQL statement, check parcel ID' print 'Please verify the Parcel ID and try again' return userinput(); elif str(result) > 0: df.zoomToSelectedFeatures() df.extent = parcels.getSelectedExtent(True) df.scale *= 1.65 arcpy.RefreshActiveView() print 'Exporting to pdf...' pdf = pdfpath + str(parcel_num) + '.pdf' pdfname = str(parcel_num) + '.pdf' if arcpy.Exists(pdf): arcpy.Delete_management(pdf) arcpy.mapping.ExportToPDF(mxd,pdfpath + str(parcel_num) + '.pdf') del mxd print 'PDF Exported, to view open ' + str(pdfname) + ' in the "PRINT MAPS" folder.' print 'Sending document to default printer' #### Print PDF Code thanks to Luke Pinner ##### # '"%s"'is to wrap double quotes around paths # as subprocess will use list2cmdline internally if we pass it a list # which escapes double quotes and Adobe Reader doesn't like that cmd='"%s" /N /T "%s"' %(acroread,pdf) proc = subprocess.Popen(cmd,stdout=subprocess.PIPE,stderr=subprocess.PIPE) stdout,stderr=proc.communicate() exit_code=proc.wait() print 'Successful' except: print arcpy.GetMessages(2) try: userinput() except: # Get the traceback object tb = sys.exc_info()[2] tbinfo = traceback.format_tb(tb)[0] # Concatenate information together concerning the error into a message string pymsg = "PYTHON ERRORS:\nTraceback info:\n" + tbinfo + "\nError Info:\n" + str(sys.exc_info()[1]) msgs = "ArcPy ERRORS:\n" + arcpy.GetMessages(2) + "\n" # Return python error messages for use in script tool or Python Window arcpy.AddError(pymsg) arcpy.AddError(msgs) # Print Python error messages for use in Python / Python Window print pymsg + "\n" print msgs # Print Log file txtFile = open(txtfile, "w") txtFile.write(pymsg) txtFile.write(msgs) txtFile.write(query) txtFile.close()
Thanks for sharing this!!Is there a way to specify printer options using this method? Specifically, set color or black and white, paper size, scaling, print quality, etc.?
I would recommend looking at the python CUPS module, aka pycups.
import osfrom os import path from os import listdir from os.path import isfile, join import win32api import win32print mypath = r"\\<your path goes here>" #list all the files in a folder files = [ f for f in listdir(mypath) if isfile(join(mypath,f)) ] for file in files: file = mypath + "\\" + file if "11x17" in file and "County" in file: win32api.ShellExecute ( 0, "print", file, # # If this is None, the default printer will # be used anyway. # '/d:"%s"' % win32print.GetDefaultPrinter (), ".", 0 ) del files del mypath
#Lists properties and capabilities for all the printers installed on a computer. import win32com.client strComputer = "." objWMIService = win32com.client.Dispatch("WbemScripting.SWbemLocator") objSWbemServices = objWMIService.ConnectServer(strComputer,"root\cimv2") colItems = objSWbemServices.ExecQuery("Select * from Win32_PrinterConfiguration") for objItem in colItems: print "Bits Per Pel: ", objItem.BitsPerPel print "Caption: ", objItem.Caption print "Collate: ", objItem.Collate print "Color: ", objItem.Color print "Copies: ", objItem.Copies print "Description: ", objItem.Description print "Device Name: ", objItem.DeviceName print "Display Flags: ", objItem.DisplayFlags print "Display Frequency: ", objItem.DisplayFrequency print "Dither Type: ", objItem.DitherType print "Driver Version: ", objItem.DriverVersion print "Duplex: ", objItem.Duplex print "Form Name: ", objItem.FormName print "Horizontal Resolution: ", objItem.HorizontalResolution print "ICM Intent: ", objItem.ICMIntent print "ICM Method: ", objItem.ICMMethod print "Log Pixels: ", objItem.LogPixels print "Media Type: ", objItem.MediaType print "Name: ", objItem.Name print "Orientation: ", objItem.Orientation print "Paper Length: ", objItem.PaperLength print "Paper Size: ", objItem.PaperSize print "Paper Width: ", objItem.PaperWidth print "Pels Height: ", objItem.PelsHeight print "Pels Width: ", objItem.PelsWidth print "Print Quality: ", objItem.PrintQuality print "Scale: ", objItem.Scale print "Setting ID: ", objItem.SettingID print "Specification Version: ", objItem.SpecificationVersion print "TT Option: ", objItem.TTOption print "Vertical Resolution: ", objItem.VerticalResolution print "X Resolution: ", objItem.XResolution print "Y Resolution: ", objItem.YResolution print "---------------------------------------------------"
Luke,
Your example certainly helped me in getting started. The hard part for me was hard coding the path for adobe as it is not that flexible and would require each machine to be at the same level of Adobe Reader. This led me to look for a more dynamic way of handling this so I thought I would share my findings if anyone should come across your post. I still had problems with ArcMap locking when the pdf was open and had to manually kill the adobe process in task manager to free up ArcMap so I issued a simple command to kill the process after 5 seconds allowing adobe reader to open the document, and send the pdf to the print spool. In our case we were automating a report using an *.rlf file and exporting it to a pdf, we needed a way to print both a map and the report which is what the below was doing. Thank you for your contribution and sharing your code!
import _winreg as winreg import time, arcpy, os, subprocess # This is where you would specify the path to your pdf pdf = 'Place the path to your pdf here.pdf' # Dynamically get path to AcroRD32.exe AcroRD32Path = winreg.QueryValue(winreg.HKEY_CLASSES_ROOT,'Software\\Adobe\\Acrobat\Exe') acroread = AcroRD32Path #print('variable acroread is : {0}'.format(acroread)) # The last set of double quotes leaves the printer blank, basically defaulting to the default printer for the system. cmd= '{0} /N /T "{1}" ""'.format(acroread,pdf) # See what the command line will look like before execution print(cmd) # Open command line in a different process other than ArcMap proc = subprocess.Popen(cmd) # 2 lines below would not close adobe reader and locked ArcMap. #stdout,stderr=proc.communicate() #exit_code=proc.wait() # Needed to put a sleep in here so the command line had time to open the pdf and spool the job to the printer. time.sleep(5) # Kill AcroRD32.exe from Task Manager os.system("TASKKILL /F /IM AcroRD32.exe")
That is pretty cool, Ken! In the past I have just used glob, which should also find AcroRd32.exe no matter what the version:
acroread = glob.glob(r"C:\Program Files (x86)\Adobe\Reader*\Reader\AcroRd32.exe")[0]
I like yours better though. I was also having issues with adobe reader remaining open after PDF was printed so thanks for sharing termination part!
I got it . Thank you very much for your help. Translation courtesy of Google .
From Spain
