I have an empty table with an integer type field, let us call it "field1"
I want to populate field1 with numbers ranging from 1-5, so that my table looks like this
OBJECTID FIELD1
1 1
2 2
3 3
4 4
5 5
I have come across this example - How To: Create sequential numbers in a field using Python in the Field Calculator
But do not know how to adapt it to fit my need.
Regards,
Similar question to In Field Calculator 1 To 9 Loop Numbers.
Pre-Logic Script Code:
<SPAN class="keyword token">from</SPAN> itertools <SPAN class="keyword token">import</SPAN> cycle rot <SPAN class="operator token">=</SPAN> cycle<SPAN class="punctuation token">(</SPAN>range<SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">6</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">def</SPAN> <SPAN class="token function">next_number</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">return</SPAN> next<SPAN class="punctuation token">(</SPAN>rot<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Value:next_number()
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
