I would like to know how I can monitor arcgis data store health or the response of hosted feature resource because there is in same case the hosted feature stop to responding and a I need restart the arcgis service service.
Hi @EdnaKanazawa,ArcGIS Monitor does not currently supporting registering the ArcGIS Data Store as a component.As for getting data metrics on hosted feature services, please review the discussion in this thread,Unable to see published hosted feature layer in ArcGIS Monitor 2023
Hope this helps,
Although as @DerekLaw pointed out, data store is not a supported component, users can potentially monitor availability using combination of host, db components and server logs. Note, ArcGIS data store does not have a direct "health check" call.
Curious if adding the data store is going to be a supported workflow in the future? If so, any idea as to when?
Matt
Hi @mhudson, > Curious if adding the data store is going to be a supported workflow in the future? If so, any idea as to when?This enhancement is under consideration. We don't have a timeline on when this will be enabled.Hope this helps,
Hi @EdnaKanazawa,FYI: The ArcGIS Monitor 2023.3 release, now collects metrics for hosted feature services for ArcGIS Enterprise 11.1 and later releases. Please review the blog,ArcGIS Monitor 2023.3 Now Available!!Hope this helps,
